Fuel pump Q?
I have to change the fuel pump on my sea strainer! Maybe a dumb Q? But I've been trying to get the holley 110 GPH pump # 712-454-11. No one has it and the local store has the 12-454-11 but its for the car no vent tube! Well my vent tube has been pluged and not working sence last year! Any how I just freshend the motor and need to change it! Q? Is can I use the 12-454-11 or just order the right one, and wait a few more days! Either way no biggie the other one is just here if I can use it with no vent tube?
I'm assuming the fuel pump you have is on your sea PUMP, not sea strainer. If so, a regular holley pump designed to be used on the engine block, won't work. The arm is different
Mild thunder! Thanks didn't even think about that! How much H-power do you think the stock pump will support?
Originally Posted by MILD THUNDER
(Post 4302914)
Originally Posted by dereknkathy
(Post 4303574)
so what pump fits the raw water pump?
http://www.cpperformance.com/p-12460...6-engines.aspx This is the only upgraded sea pump mounted fuel pump that I know of. Other than that, remove the pump, install a block off plate, and go to an electric pump. Eddie |
Originally Posted by Mike S.
(Post 4303556)
There are different part numbers for the fuel pumps on different Merc engines. |
Originally Posted by Young Performance
(Post 4303588)
This one.
http://www.cpperformance.com/p-12460...6-engines.aspx This is the only upgraded sea pump mounted fuel pump that I know of. Other than that, remove the pump, install a block off plate, and go to an electric pump. Eddie http://www.cvproducts.com/Products.a...h=SPIN-MP-2630 A thread on OSO: http://www.offshoreonly.com/forums/g...fuel-pump.html |
Ok so what's a good elec. pump that yall are running that will handle 600-650 hp with no bypass set up! Holley, aeromotive, magnafuel, etc. I wanted to keep my sea pump, pump but I guess I could go elec. he'll some elec are the same cost lol
| All times are GMT -5. The time now is 03:57 PM. |
