Let the guessing game begin as what broke in 502 mag EFI
#91
nsx, wasn't implying that you didn't know what you were doing on the top end rebuild. I was just commenting on the darkened area between several cylinders that looked in the pictures like a possible blown head gasket. You had mentioned that it had a previous blown head gasket, and you cannot typically deck a block without completely tearing down the bottom end. You mentioned that the block had the proper RA for MLS gaskets - do you have access to an RA tester to verify? Maybe you did. Just tossing some things out there in hopes that you can find the root cause.
#92
You have a good one here . Had a nice piston top color across the board , had that clean spot that kinda said water has been here on that ganked piston . Mls gaskets are majic for 502s but its a ***** getting all that surface area of all that cast iron straight smooth and square. Have never ever seen one fail from being to smooth , if its square. Didnt see that worn nickel from the '70s finish , but im half blind too.
My bet says clogged block passages and or water intrusion on that compromised cyl . Good news is if im right the rods mains ect will be unscathed. But if im wrong ...
#93
Looks like that piston chunk took a little tour around to visit a few other cylinders before the party plug was pulled
I would take a real close look at how the water is flowing around that damaged cylinder. The appearance of cooked graphite could possibly hold another clue
#96
Just bought this boat natural high
Hi , I just bought the boat in this thread. Does anyone know why he changed the 502 out. The boat has a 7.4 l in it now. Does anybody know why he did this. The owner had passed away and I purchased it from his son.
#97
If you are referring about the OP, 92NSX, he is very much alive. He is a part of another forum. Sure he bounces over here once in s while too.
92nsx (08-26-2020)
#98
Interesting
Anyways after this supposedly being a great boat with no problems turns out to not be the case. Well I’m ordering parts for a 7.4 l I come to find out on this thread that this boat originally had a 502 efi . Would you happen to know why the motor swap?
also reading past threads I see this boat was supposed to be being parted out due to a cracked hull. Wondering if that’s the reason it’s taking in water at my slip ? Any I do o. This boat is greatly appreciated.
#99
92nsx (08-26-2020)
#100
I did not sell that boat with a 454. I sold it to Chris in 2015 or 16. Had a 502 mpi that had 325-350 hours on it. He was from Illinois but keeping the boat at his cabin in Wisconsin.
I sold it as a parts boat for 6 or 6500( the value of the engine and drive ) . The port side hull was cracked, port side right by the outer chine, cockpit / engine area. I have photos of it some where. Plus more. The back cross member on the trailer that is bent into tuseday.... was from when i dropped a axel at the landing.
So some where down the line he swapped the engine putting in a lower performing engine. The registration and trailer I see is still in my name. So he obviously never switch the titles.....
articfriends (10-22-2021)
