-   -   Crossover question??? (https://www.offshoreonly.com/forums/general-q/32698-crossover-question.html)
puder 09-10-2002 12:46 PM
I got my engine (basically a 525SC) but my old circ pump doens;t seem to fit. That's ok becasue it is super smarmy (in ****ty condition for those of you that don't speak puder)
I figured instead of gettinag new circ pump i might installa crossover. What would be the advantage other than not having to waste 5hp turing a circ pump? I have heard crossovers can casue the block to hot spot any truth to that?
Also how whould i plumb it??? I have CMI so need to know the "proper" way to route all my water hosesd and such.
puder 09-10-2002 12:49 PM
also which crossover should I get? I have seen like 5 diferent designs and they all havea different number of hose connections on them.
Panther 09-10-2002 01:12 PM
crossover
I would recommend any crossover that has a thermostat. Don't put one in without a themostat. You'll never get the motor to temp, and never burn off the moisture in the oil etc. It't also not good to run the motor cold anyway. You'll have premature engine wear.
The crossover that is set up for a themostat will have a bypass hose, which will go from the thermostat housing to the actual cross over. I always use a 140* thermostat.
Plumbing it is easy. It basically goes the same path of the existing system. Your presure hose goes into the cross over. The bypass hose goes from the top of the cross over to the thermostat housing. The two hoses from the headers also connect to the thermostat housing.
I have been running crossovers for a very long time, and never had any problems, and I doubt you will either.
Panther 09-10-2002 01:14 PM
and adavntage
Also, one of the advantages for you may be a little bit more power. I mean a fraction. And also it is one less part that will break or wear out. I have never had to replace one that was made of stainless. They seem to last forever.
puder 09-10-2002 01:28 PM
can anyone post a pic of thier engine with a crossover?
obnoxus 09-10-2002 01:38 PM
I would install a water pressure guage as well,,, several people here have put crossovers on and buried the guage, most have gone back to recirc pumps,,,, just a heads up,, good luck.
puder 09-10-2002 01:46 PM
i did actually buy water pressure guage. where do i install the sender? It apperas to just screw in, but where is the proper place to screw it into?
Nordicflame 09-10-2002 01:54 PM
Maybe this deserves a thread of it's own but here we go again.
Water pressure????????????
This was in a post from the General Discussion (496 Goodies)
"With all our systems, we stress water pressure, we even have a Mercury Racing bulletin that states the same, they want a minimum of 25lbs. and maximum of 35lbs. @ WOT on all of their engines no matter what"
:confused:
What is the real answer here?????? All of the previous post state 5 at idle and 22 max at WOT.......
:confused: :confused: :confused:
Panther 09-10-2002 02:32 PM
Follow the leader
Why not follow the leader, and do what the pros. do. Outerlimits puts valves that bleed off excess pressure. I was in my buddies Outerlimits once and he had valves in the floor that you would adjust while cruising to achieve proper water pressure. Set the pressures at about 10lbs while cruising and then nail it. All that it is, is a simple on/off valve that you open to bleed off pressure. You only need to do this on a boat that is very fast. I have only seen water pressure problems on boats that run over 85mph.
obnoxus 09-10-2002 02:55 PM
All of the people I know withproblems run in the 60's and 70's
ALFSTER 09-10-2002 03:36 PM
puder
Make sure you run the correct thermostat for a cross over set up.The thermostat has small bypass holes in it ,to keep it from constantly opening and closing due to the cold water entering thru the bypass.
WETTE VETTE 09-10-2002 04:47 PM
I have a solution for the water pressure problems that come with high speed and crossovers. For 100 bucks you get the special stainless tee, the adjustable dump valve and the necessary fittings. The only thing you need to purchase is some 3/4" heater hose and a through transom water dump. It works great. Let me know if interested.
Craig
FloridianSon 09-10-2002 07:04 PM
1 Attachment(s)
Hay Pudder 150.00 and it's yours if it will work,Stainless Marine minus the PFM valve.
RLW 09-10-2002 08:13 PM
I would like to see the Mercury Racing Bulletin. Is that possible?
puder 09-10-2002 08:56 PM
if it will work i will take it!
I snap apic of my engine so you can see mysetup and you guys can let me know if it will work.
Bad to the bone 09-11-2002 08:06 AM
Had have crossovers had way to much water pressure engine
guy installed a restritor made by moroso they have different
size to get the pressure you need. Work great no problems since
FloridianSon 09-11-2002 09:24 PM
Pudder I was looking at the stainless book and I think that mine will not work on your setup. It is called the( big block kit with bypass port entry).They offer quite a few kit's so if you call Stainless they could tell you if it would work.(305)681-7893
B.R.S. 09-11-2002 09:38 PM
1 Attachment(s)
Puder I got mine from CP Performance and have run them for 3 seasons. I have the thermostat. Temp is a perfect 150 deg and never moves. 18# pressure at WOT. The work excelent and I was even able to use the factory outlet hoses. I did fabricate a solid hose going from the cooler to the bypass out of copper plumbing pipes and fittings and painted it black. Works great but I am in fresh water.
