oil pan related question
On a stock gen V HP500C, there's a windage tray (I hope this is the correct term) that is bolted to the center studs on main caps 3 and 4. I have a 10qt Hardin "XS" pan which has a tray bolted to the interior of the pan.
Am I correct in assuming the stock tray is not used with the Hardin pan? Thanks, Ryan |
yes you are.
Thank Mike.
My other assumption is the stock bolts that have the mounting studs for the tray will not pose an interference problem with the Hardin tray - hopefully this is correct also. The Hardin literature makes no mention of the bolts needing to be changed out. Ryan |
Originally Posted by Ballistic Beak
(Post 4313469)
Thank Mike.
(Post 4313469)
Thank Mike.
I would replace them with a standard type bolt, cutting them off could weaken its strength jmo
I had protruding studs left over from a dry sump segmented pan on the main studs.
We put the studs in a lathe and cut them off. |
I called Hardin with that exact question . The stock windage tray is not reused and I went with new ARP main bolts and an align hone .
Thanks all
Ryan |
| All times are GMT -5. The time now is 12:06 PM. |
