-   -   Older 110s kplane (https://www.offshoreonly.com/forums/general-q/327207-older-110s-kplane.html)
camptappakeg69 06-10-2015 05:35 PM
Older 110s kplane
I have the older 110 kplane with the trim pump and cylinder all in the same assembly, what fluid should I use in them. Had to replace a leaking gasket not sure what was in there...gear oil, motor oil, hyd fluid?
