What cam button???
In process of putting my engine back together and I installed a polished aluminum front cover instead of the stamp steel. I looks as if my cam button is too long. Current button is .940". Does anyone know what button will get me a little closer (I can machine off some of the cover for the right fit)
Its a Mark IV Roller cam |
i use a small block button with the edelbrock timing cover but you may need an xtra gasket or two to get the desired cam end play.
I will try that, thanks
SB button worked perfect, thanks
| All times are GMT -5. The time now is 04:07 PM. |
