quickfuel carbs
#41
EZ what CID is your rngine and cam specs, reason is I'm trying to help out a buddy with a procharger running very rich. anyinfo you can send oour way would be greatly appreciated. Don't ask who did his carb!! if we can get it to run right then I will tell you.. It is NOT a QF carb,. they seem like real good folks.
#42
Ok, tested fri afternoon, carb now spot on, 10.8-11.2 @ WOT 12.8-13 cruise & idle, clean accell and starting. very pleased with the quickfuel carb and Zach on their tech line, once we put ours heads together and got the restricters and bleeds from summit, was able to dial it in pretty quick, but without a wideband 02...NFW...Rob
