-   -   Water Pressure Gauges (https://www.offshoreonly.com/forums/general-q/327331-water-pressure-gauges.html)
682gold 06-15-2015 06:14 AM
Where do the water pressure gauges hook up in the back? I had new engines installed and had my drives checked while off. They worked before but now do not. What has not been hooked up? Bravo 1 drives. Both gauges are hooked to the tubing.
Kelly O 06-15-2015 11:31 AM
Fountain hooked those years' gauges into the block drain ports, center of the block. Typically have a swivel fitting on end of hose, will require an adapter installed into block to hook hose to.
682gold 06-15-2015 04:43 PM
So follow hoses back from gauge and see where they come to in engine compartment. Find a drain cock in block and put a hose fitting on it? Like an AN fitting or a push lock?
Kelly O 06-15-2015 04:54 PM
Ones I've seen were J.I.C. male (hose end should be female swivel) that adapted to pipe thread male screwed into block. Best to use a straight adapter so can run wire up through when disconnecting to winterize. Wire helps poke out grit/flakes that plug fitting when lines removed to drain blocks.
682gold 06-15-2015 10:04 PM
I guess I am asking if there is one particular place in the block to connect the hose too?
