How to tell the difference ?
Those old alpha drives. How can you tell the difference of what generation they are. The one I have off. The trim are that are attached to the upper.. Are mounted at the very back of the fin on the case.
That sounds like a Gen I...Gen II are mounted further forward
Gen II's also have a swept back skeg |
The Gen 1 has the lower attached to the upper with studs and nuts, like a Bravo. The Gen 2 Alpha has the lower attached to the upper with nuts and bolts. It is through bolted together.
Eddie |
| All times are GMT -5. The time now is 12:38 PM. |
