slight miss when i hit the Trim ?
It seems that when i hit the trim i hear a slight miss. I noticed this today while headed back to the marina to get back in time to get it yanked out i was running from 3500 -4000 RPM and it just not seem to sound right and sounded like a miss when i would hit the trim ?
I usually run it at 2800 RPM. Boat is a 1993 Powerquest 290 T- 454 330HP --798 hours--other engine is at 793.. ? New batteries last year. I bought it 2 years ago so this is my third summer. I have not touched the belts, plugs or wires everything is so clean .. and it starts and runs great... |
Battery (ies) or alternator...most of the time. Obviously this includes cables/grounds/etc.
Drive trim and trim tabs take a good amt of power to use, if batteries don't have enough power to handle the sudden inrush of current, your engine will miss. |
Dirty, loose connections especially grounds. The trim draws a lot of current which makes it worse.
Thank You will be on it when i get back out there.... i was thinking the same thing,,, but wanted to run it across the knowledgeable people of OSO
