-   -   Help with 502 Mag (https://www.offshoreonly.com/forums/general-q/327625-help-502-mag.html)
GLOC336 06-22-2015 12:43 PM
Help with 502 Mag
Having problem with my 502 mag dying after being run for 20-30 minutes. Dies and just will crank with a little spitting and sputtering. Let it sit and cool off for a few hours it fires right back up just fine. Any ideas?
ziemer 06-22-2015 12:54 PM
Sounds like vapor lock. These motors are notorious for vapor lock especially with the VST system, but will also do it on the cool fuel 502's.
Do a search on here and you'll find a bunch of topics. ;)
liquidlounge 06-22-2015 02:16 PM
exactly
buck35 06-22-2015 02:20 PM
I have never had the engine die while running around, mine would just not start after an extended shutdown, maybe but it could be electrical as well.
ALL_IN! 06-22-2015 02:39 PM
Many of us have/had same problem on 502 MPI's. I went the Merc route and installed their add-on pump. It worked really well, and I never had the issue again (you can install this yourself easily). Others have run return lines back to tank, installed better pumps, etc. Many ways to skin a cat.
buck35 06-22-2015 08:33 PM
If you happen to venture out again and this happens check and see if you have spark, could be a coil about to take a crap.
GLOC336 06-23-2015 07:39 AM
Thanks for the info. This motor has the mechanical pump on the sea water pulley, is that the add on you are referring too? If so I replaced it this winter
92nsx 06-23-2015 12:20 PM
Mechanical pump feeds the electric fuel pump inside the VST located above# 7 cylinder. Unless your carb 502 mag.
