-   -   1075sci (https://www.offshoreonly.com/forums/general-q/327827-1075sci.html)
coldshoe1 06-27-2015 11:53 AM
1075sci
Anyone have any ideas why brand new refreshed from Mercury Racing 1075 would lose oil pressure, alarm come on when coming down off plane when hot? Thanks
14 apache 06-27-2015 03:05 PM
Collapsed oil filter. Cut it open and take a look. If your lucky that's all it is.
hullofjustis 06-27-2015 03:14 PM
oil pressure could actually be low obviously, oil level is incorrect and is moving from the pump when coming off plain.
quality of oil, grade of oil I have seen cars at idle do that change the oil and it fine..
I have heard something about fram filter collapsing as well
Craney 06-27-2015 04:10 PM
Cobra did the rebuild!!
Unlimited jd 06-27-2015 04:42 PM
Collapsing suction hose from dry sump tank to the pump?
sutphen 30 06-27-2015 07:33 PM
whats the oil pressure when running?If you find nothing wrong w/ the filter it may be as simple as shimming up the oil pressure relief valve.
14 apache 06-27-2015 10:10 PM
Oil pressure spring will only limit the pressure that would not cause it to be low at hot idle.
activator40 06-28-2015 06:59 AM
Originally Posted by craney (Post 4323447)
cobra did the rebuild!!
bwahahhahahahhahahahaaahahhhahahahahaaaahahaahhaha hahaahahahah.
Keith Atlanta 06-28-2015 07:59 AM
Is it actually losing oil pressure or just dropping below 25psi?
What oil are you running?
Hopper 06-28-2015 08:30 AM
LMFAO.... that would suck
Craney 06-28-2015 11:33 AM
Are they dry sump or oil pans?
14 apache 06-28-2015 11:36 AM
all 1075s are dry sump.
