-   -   Exhaust Question (https://www.offshoreonly.com/forums/general-q/327998-exhaust-question.html)
Black Baja 07-03-2015 09:01 PM
Originally Posted by sutphen 30 (Post 4325688)
I never had a problem in my boat w/ gil's but always hated doing plugs in a gen3 manifold,the plugs near the water inlet suck.
Yeah I think if the fitting was an inch or so longer to drop it down off the manifold some it would make life much easier.
DiamondPerformance 07-04-2015 07:08 AM
1 Attachment(s)
We have been working on making them more appealing!
benjen 07-04-2015 07:25 AM
What size are the internal tubes? I guess as long as I have your attention what are the tailpipe size options as well?
DiamondPerformance 07-04-2015 07:30 AM
The runners are 32" long. The stock Bravo tailpipe is 6" . http://www.diamondperformanceparts.c...cat=282&page=1
benjen 07-04-2015 07:55 AM
Yes, I have seen that link. I meant inside diameter. I assume by your tall pipe answer these do not run "solid" tailpipes from manifold to back of boat. We run dry exhaust!
Black Baja 07-04-2015 07:57 AM
Bill do you have anyone that can make dry tails for the manifolds?
benjen 07-04-2015 08:01 AM
Of course that is what i meant by dry exhaust............dry tailpipes!
Black Baja 07-04-2015 08:06 AM
I know what u meant. We were posting the same question at the same time. I think I spoke to Bill about tails b4 some time ago and he had someone that could make them. Just can't remember for sure. I've actually thought about running the tail pipes out the sides of the hull just not sure if it would look gay or not.
benjen 07-04-2015 08:23 AM
Originally Posted by black baja (Post 4325732)
i know what u meant. We were posting the same question at the same time. I think i spoke to bill about tails b4 some time ago and he had someone that could make them. Just can't remember for sure. I've actually thought about running the tail pipes out the sides of the hull just not sure if it would look gay or not.
why
DiamondPerformance 07-04-2015 08:47 AM
Yes, I have someone to weld the pipes. Side exhaust looks good! 4" diameter of the stock tailpipe.
