Carb question. Is this suppossed to be open?
I'm not too familiar with the inner workings of carbs just yet. Any other motor part, I have a good grasp on and can handle.
But here's my carb with the flame arrestor off: http://i47.photobucket.com/albums/f1...pscnbfidhi.jpg The past few days the boat has been giving me some trouble starting, even after it was just ran and engine is warm. It tries to crank, but just doesn't catch. I pump the throttle and keep it all the way WOT for it to start, and just bring the RPMs down right away once it does start. So it got me looking at my carb. I see different vacuum/diaphragm looking things that open and close these plates and thought maybe there is an issue. So, long story short, in the pic above, is that how it should be or is something not working properly? Thanks, |
The one that is open is for the choke. I have mine set wide open all the time just like yours.
Sounds like the the carb is dripping fuel from the welsh type plug. This drains the carb making a cold start hard as the carb needs to get fuel first to fire. It makes hot start hard as it floods the engine once you shut it off, hence the reason you need to hold the throttle wide open.
This is a common problem with Q-jets |
Agree with above:
Since you are interested, buy a book "How to rebuild your Rochester Quadrajet," put it in the front of the books you have stashed in the bathroom (man's library) and read it...then reread it...then reread it...on and on and on. If nothing else, you will have a great learning experience. And, yes, you can learn a ton while sitting in the john. |
Im sitting on the john right now . Thats a unmolested early qjet set up there for sure . The fuel pump ddibble line isnt even rotted and falling off.
Epoxy the well plugs and bring it up to corn gas standards and should be fine (New float, keep fuel lines cool and maybe take the float level down a notch if your in warmer climate) |
Is that a marine carb?
I spent years of my youth playing with Q-Jets. Bought a Quickfuel and I've been super happy with it. |
Originally Posted by airjunky
(Post 4326810)
Epoxy the well plugs and bring it up to corn gas standards and should be fine (New float, keep fuel lines cool and maybe take the float level down a notch if your in warmer climate) This is OSO -- you should be sitting in the HEAD never the Toilet!! hope everything worked out! 3pointstar |
That's a marine carb, hence the barb just left of center for the mechanical fuel pump.
Another issue that can be happening is a fuel pump bladder/ valve that's bleeding off pressure after it sits. |
It looks as though some reading is a head of me.
I deal with throttle bodies on cars mostly, never a carb, so Im still a novice on that. |
If there's the smell of fuel in the crankcase, that could be your problem. Also, if that carb is an unmolested original, I'd rebuild it. You'd be amazed at how much crud is in a marine fuel tank.
I rebuilt mine a couple years ago. Engine was very temperamental when cold, wouldn't idle for **** until it warmed up. Upon tear down I found that the idle screws were way off and one of the metering rods was not seated in its spring correctly. It was running like crap, hence the rebuild. After that its ran great the last few years, idles good cold or hot, no stalling, good to go.
I have rebuilt many Q-jets over the years, and once they are set up properly they are a very good carburetor. The ones that were put on the stock 330's can flow 750 cfm, which is plenty for a mild 454. I think a lot of the bad rap that these carbs get is due to the complexity - instead of just changing jets and power valves, you have jets, rods, and hangers to change. But once you get it down, they are not that bad, and the flexibility makes them very adaptable to a number of engine platforms. Best thing to do is buy a couple of books about Q-jets to learn more about them. Basic rebuilds are pretty easy - really no harder than a Holley. Cliff Ruggles up in Ohio is an expert on Q-jets and has a good website with a lot of info about them and an active user forum. He also has an excellent book about them that reveals the theory behind their operation and performance mods that can be made. There are a lot of Super Stock drag cars making big power with Q-jets. Cliff also has an excellent rebuild kit that has everything you need to properly rebuild one to handle the E-10 gas that we are now saddled with.
In regards to the well plugs leaking - that has always been an achilles heel with these carbs, but it is something that can be fixed. Epoxy over the plugs is a temporary solution, as it will eventually leak again. The best fix is to simply drill the plugs out, tap them, and install some plugs with epoxy on the threads. |
| All times are GMT -5. The time now is 10:16 PM. |
