Can I use Power Steering fluid for Trim Tabs
One of my Trim Tab reservoirs was low last weekend and my Tab stopped working. I didn't have any ATF Fluid on board so I put some power steering fluid in it and it started working again. I know they are both hydrolic type fluids so can I just leave what I have in there or should I pump it out and go with straight ATF?
Thanks TC G |
I use 30wt motor oil
You can....just keep in mind that different hydraulic fluids have different viscosity's, so by mixing fluids and changing the mixture you may get one tab working faster or slower then the other since the pump will be pumping the fluid easier/harder....
You will be fine.
If there is any change in the speed of the the tabs, that will be short lived until the fluids gets all mixed together. Chances are you won't notice any difference. ATF and power steering are pretty close in viscosity, 30wt motor oil is way more viscous. If you needed a lot of fluid, your tabs would probably be slower with the 30wt. Ken |
Originally Posted by Black Baja
(Post 4327867)
Padraig |
(Post 4327867)
Originally Posted by Padraig
(Post 4327988)
That is what my Dana tabs call for.
Padraig |
There are differences in how power steering or trans fluid and motor oil react with seals. Never use motor oil when ATF or Power Steering Fluid is called for. Also motor oil doesn't have the anti-foaming agents that ATF or power steering fluid have. which can make your hydraulics spongy. Just saying.
I run 10-30w in my 280s.
Originally Posted by ThisIsLivin
(Post 4328279)
| All times are GMT -5. The time now is 04:54 AM. |
