Just add some blow by to it than watch.
Originally Posted by MILD THUNDER
(Post 4328066)
I found it very "relevant" to this topic. I'm just a truck driver, so it could be my feeble mind.
A video showing how the screens simply restrict the flow of oil, from a guy who builds some of the biggest, baddest, high powered, innovative marine engines out there, is irrelevant and stupid. Or him simply suggesting in the video, that if you run a high volume pump at extended periods of high rpm, to "be careful". And how the proper screen size, is important. Totally not relative to the OP's question. :rolleyes: What are your thoughts about a big block long stroke marine engine turning high rpm, and the crankcase windage trying to push air up thru those screens, while oil is trying to drain thru them? Is there any truth in that, or is that irrelevant as well? thank you, for your continued great technical insight you, once again, have brought to the forum. Watching a guy dump a gallon of oil on top of the screens proves nothing other than if ANY filter media is instantaneously flooded it can become overwealmed for a moment. Tell us about what you read in super chevy about the long arm BBC. |
(Post 4328066)
Originally Posted by vintage chromoly
(Post 4328092)
http://i205.photobucket.com/albums/b...ps6rbkfasl.jpg
Watching a guy dump a gallon of oil on top of the screens proves nothing other than if ANY filter media is instantaneously flooded it can become overwealmed for a moment. Tell us about what you read in super chevy about the long arm BBC. You finish your first ever engine build with 47 people holding your hand along the way? Whats it been 2 or 3 years now? Maybe you should start reading about engines instead of huffy bicycle modifications I know , alexi from boostpower is stupid. Hopefully he reads your posts here and learns a thing or two from you. |
(Post 4328098)
I know , alexi from boostpower is stupid. Hopefully he reads your posts here and learns a thing or two from you. Never said the guy was stupid. Just that dumping a gallon of oil in the valley is not relevant to the question of wether or not to use screens. You have the emotional composition of a teenage girl MT. |
(Post 4328092)
If it was oil with nano technology , it would have flowed right thru those large enough to see thru perforations.
Psst: I don't believe it was the experience of Alexi, it was just the visual shown that wasn't very accurate. I'd like to add that oil temperature has everything to do with flow rate and flowability. A made up word. Ha ! |
Originally Posted by 14 apache
(Post 4328089)
Maybe you should use 5W20 oil if you use valley screens? :party-smiley-004:
Originally Posted by Black Baja
(Post 4327949)
My buddy has 5 Katech motors that came out of the Lemans Corvettes not one of them had screens. And your talking about oil systems with 4 gallons of oil. And the oil pan has everything to do with it if you are going to restrict the flow back to the pan.
| All times are GMT -5. The time now is 09:23 PM. |
