Originally Posted by MILD THUNDER
(Post 4396639)
Oh man. You do realize you're getting into an oil debate with Borgies BFF dont you? :popcorn:
it never ceases to amaze me some of the things people post around here from time to time!bet some don,t know that you should never fill your gas tank more than3/4ths full or the engine can get flooded.:cartman::confused:
Someone is going to misquote the Ford study SAE 2003-01-3119.
This is a gross miss-representation of what SAE Technical Paper 2003-01-3119 determined. The title of the paper is - "Antiwear Performance of Low Phosphorus Engine Oils on Tappet Inserts in Motored Sliding Valvetrain Test" The test was a pure wear test using externally driven valve train components. A complete engine was not involved. There was no dilution of the oil by blow-by, no combustion products added to the oil, and no water added to the oil. The results might matter if you are building a sealed machine driven by an electric motor, but trying to claim this paper is a basis for extending oil change intervals is not reasonable. Jekyl |
I read about endeavors with big engines and blowers on here all the time, I love it but am thankful for my small block Chevys' .They just run hard and don't ask for anything.Jekyl
Originally Posted by BUP
(Post 4396650)
With that said whoever said changing your engine oil too much causes extra wear, I guess you need to call Merc and tell them all about it.
I always liked the rule..... N/A engines 20-25 and Blower Engines 10-15hrs. You always get some fuel forced and wash the Pistons on blower motors, you don't want fuel diluted oil.
| All times are GMT -5. The time now is 04:55 AM. |
