-   -   Wide band O 2 a sensor placement (https://www.offshoreonly.com/forums/general-q/328774-wide-band-o-2-sensor-placement.html)
260Velocity 07-22-2015 07:02 AM
Would like some advise and pics of where guys have installed the O2 sensors on a wet exhaust
I have IMCO Powerflow manifolds with SS risers to a short PC rubber hose to thru transom stub pipes
Thanks Bill
ramos45 07-22-2015 02:02 PM
1 Attachment(s)
[ATTACH=CONFIG]543415[/ATTACH]
You can see here wherei put mine.
260Velocity 09-20-2015 10:11 PM
thanks Ramos45, Is there anyone else how has some pics of the locations for O2 's in Manifold exhaust systems?
Br1dgemann 09-21-2015 09:20 AM
When I needed a wideband do my fuel map, I used a stock big block Mercruiser exhaust manifold and riser and purchased an adapter plate to sandwich it between the two.
