-   -   Water pressure Line question (https://www.offshoreonly.com/forums/general-q/328814-water-pressure-line-question.html)
Scarab28 07-23-2015 09:24 AM
What are you guys using for the water pressure line from the motor to the gauge. I have a rubber line running to the gauge but it keeps blowing off at 20 lbs pressure. Held on only with a tie wrap.
Interceptor 07-23-2015 11:37 AM
Mine have metal hose clamps. Never have had a line come loose.
Full Force 07-23-2015 12:05 PM
I use 1/8" line with compression fittings...
Griff 07-23-2015 12:34 PM
Same here. 1/8" plastic/poly tubing.
minxguy 07-23-2015 12:40 PM
The same, absolutely zero issues.
Ken
vindicator101 07-23-2015 05:33 PM
X3
Added this setup to mine 2 seasons ago zero problems.
Rookie 07-23-2015 08:49 PM
1/8" Nylon tubing with compression fittings.
This is only 6' of tubing, but illustrates what you need.
http://www.jegs.com/i/Bosch-Actron/8...FQ-PaQodiocMkA
T-Mone 07-24-2015 08:08 AM
i use #4 hose w push lock fitings
Boatally Insane 07-24-2015 08:20 AM
I used 1/4" plastic line with compression fittings.. Rust from the block drain kept plugging up the fitting for the 1/8".....
Full Force 07-24-2015 09:20 AM
I took mine off I takes next to stat housing...I have ball valves off water drains for winter draining
