Best afr gauge and O2 sensor
What is a good afr gauge and and O2 sensor kit?
we run the NGK
Originally Posted by ezstriper
(Post 4338340)
we run the NGK
I noticed that those are not a gauge. Do you leave them installed all the time?
Also is it worth having a gauge on the dash or am I better off with a one time tune with the NGK? |
Not sure if you're looking for a permanent installation or handheld for tuning, but I just ordered the Innovate handheld. If you wait a couple days I can let you know what I think of it.
I've been very happy with the MTX-L gauge / sensor kit from Innovate. I use it full time with the gauge mounted at the helm.
Good question. I've been thinking about changing out two gauges on my helm for AFRs. Gauges are cheap and lean is expensive.
I seen that the NGK is discontinued. this appears to be the replacement. Any feed back? Does it display the same results?
http://www.ebay.com/itm/Ballenger-Mo...item3ce6a3bd58 |
I have had great luck with the Innovative MTX-L ... All in one kit priced reasonable. http://www.amazon.com/Innovate-Motor...novative+MTX-L
Originally Posted by Captain YARRR
(Post 4338667)
| All times are GMT -5. The time now is 08:27 PM. |
