-   -   Alpha gen 1 vs gen 2 & TBIV vs TBV (https://www.offshoreonly.com/forums/general-q/329440-alpha-gen-1-vs-gen-2-tbiv-vs-tbv.html)
87MagnumII 08-08-2015 08:05 PM
Picking up my new boat soon. It is a 1994 with a gen 2 alpha setup. I want to put my built motor in it which is running on a 1987 TBIV ignition system. Will the TBIV function correctly in a boat that came with TBV? Will the drive lube monitor and all other accessories still work in the new boat if I put my old **** in it?
Edit: the reason I want to keep the TBIV stuff is because I'm running a v6-14 ignition module. Not sure if they make different ones for the TBV but my boat loves all the timing down low
