-   -   454worth stroking (https://www.offshoreonly.com/forums/general-q/32953-454worth-stroking.html)
excaliber 09-13-2002 07:53 PM
454worth stroking
i have a 79 chris craft excaliber with two 454s. i have the motors out and wanted to stroke them, but my engine builder told me he would only make them 496s. what i was wondering is it worth it for only the little bit of cubes? if anybody else has done this any info would be appreciated. thanks
Dave F 09-13-2002 09:23 PM
I guess it depends on how much it'll cost.
You can buy a crate 502 short block for less than 4K.
DAVE
excaliber 09-13-2002 09:33 PM
454s worth stroking
he told me around 2300 to 2500 and that was for machining the block and a good forged crank,rods andpistons. i guess iwas just wondering if i would notice a big hp difference? kinda dissipointed i found some nice 540s i was going to buy, but they were tall decks and i only have about a 1/4 inch between my to inner gil manifolds. so they wont fit without a whole lota work.
puder 09-14-2002 01:41 AM
why not a set or prochargers??? I fthe engeins are in decent shape. freshen them a up a bit for a few hundred bucks and put on a some small blowers. I doubt you wil be able to stroke them for $2500. A decent forged crank alone is at least $600.
DOCTOR DAVE 09-14-2002 06:36 AM
excaliber, what hp are your 454's originally. very general increases for stroking a 454 is 50hp and 50 lbs of tourqe. that very roughly figures to be 3-4 mph increase. these are very general quotes and so much depends on cylinder heads, cams, compression ratio. hp generally ranges from 500 to 600 hp.
KAAMA 09-14-2002 08:24 AM
Excaliber,
Who's got the tall decks for sale? :D
Doug 09-14-2002 09:29 AM
I went through the same thing with my Cigarette. I had 454-440hp cyclones. Not mutch more HP strokeing. Eather way you need crank,rods,pistons. so I sold the 454's and built 540's. If you find the right buyer for your 454's it almost pays for your new blocks and heads. Good Luck :confused: :confused:
Dave F 09-14-2002 04:56 PM
Puder,
Where can you buy a "decent" BBC crank for $600???:p
Top of the line BBC cranks cost $1500-1700
Which means "decent" cranks cost around $1000:mad:
DAVE
puder 09-14-2002 06:25 PM
1 Attachment(s)
well the forged crank that went into my new engine cost about $600 from Bruce Dudley. its a GM 1054 nitrited crank according to the biuld sheet. I sadi i neede d forged crank and to use his best judgement as to wich one. I was expecting the 454 mag crank that was in the engein but due to some hairline cracks it needed to be replaced.
As for other cranks see attached:
puder 09-14-2002 06:27 PM
1 Attachment(s)
both of these are from the Summit Catalog. Perhaps they aren't top of the line but I would be willing to call them decent. And about $600
