-   -   Going freshen up 420's (https://www.offshoreonly.com/forums/general-q/329603-going-freshen-up-420s.html)
MILD THUNDER 08-13-2015 12:09 PM
Originally Posted by onesickpantera (Post 4342302)
Just curious, what is the average cost of AFR heads?
http://www.dfperformance.com/afr_bbc325_335.html
Budman II 08-13-2015 01:39 PM
The 265's are considerably less than the bigger 305 and 325's. I would strongly recommend upgrading to the inconel exhaust valves. Also, if you are buying them fully assembled, it might be a good idea to have guide to stem clearance checked, especially if you plan to run it hard with raw water cooling in a body of water that has cool water temps. That goes for any aftermarket head, not just the AFR's. There is an epic (now closed) thread out there on this - 'nuff said.
MILD THUNDER 08-13-2015 04:33 PM
SHHHH you'll wake the bears! :party-smiley-004:
phragle 08-13-2015 07:07 PM
Originally Posted by Tmaddox4x4 (Post 4341904)
. I ran AFR's on my LS motors in the off road race car and was real happy.
What was this racecar?? Class/Org??
Full Force 08-13-2015 08:48 PM
Lol
Originally Posted by mild thunder (Post 4342411)
shhhh you'll wake the bears! :party-smiley-004:
Tmaddox4x4 08-14-2015 05:16 AM
It was a Ultra 4 buggy, four wheel drive off road type racing. I hadn't ran in years and couldn't stand watching it sit in the shop. I pulled and sold the motor, got $9,500 for it and traded the chassis for the boat.
phragle 08-14-2015 06:49 AM
We played with this for a while.....
http://img.photobucket.com/albums/v6...agle/aero2.jpg
http://img.photobucket.com/albums/v6...agle/aero1.jpg
http://img.photobucket.com/albums/v6...agle/aero3.jpg
Tmaddox4x4 08-16-2015 06:23 AM
Ok so here's the plan. I spoke with my finance manager, a.k.a "the wife" and got the go ahead to tear them down. If the current heads are in good shape going clean them up and reuse. If they are cracked I will be replacing with Elderbrock marine heads. It currently has Thumper Power manifolds and I'd like to keep to save some cost. I plan on sending the rotating assemblies out for balanceing and inspection. Hopefully I can rerun the pistons but not a big deal if not. My goal is 500HP at not rev past 5,200. I will be converting to roller cam and replacing the crane gold lifters. Probably run a air gap intake and definitely going MSD distributor. My budget is 5k per motor, but any money I can save here will be spent on other updates, gauges, interior, paint and probably rebuild the transmissions. So my main question is what cam to run? I don't see blowers in the future, just don't want to deal with them.
Black Baja 08-16-2015 06:59 AM
MSD distributor will be a definate step down from whatever you have now.
Tmaddox4x4 08-16-2015 07:11 AM
I thought the stock mercruiser could use an update. What would you suggest? I've always run msd with little to no issues in my offroad rigs.
