Oil temperature issue >
Old 08-25-2015, 07:54 AM
  #81
Yep. Plenty of scratches on my back from that mfer lol
MILD THUNDER is offline
Old 08-25-2015, 08:47 AM
  #82
So lets see a pic of the clean oil cooler. What did you do to clean it?
drpete3 is offline
Old 08-25-2015, 08:52 AM
  #83
35fountain's Avatar
Still working on them..First i back flushed them with high pressure water. Then i took a long brazing rod and poked the holes..That was time consuming. Then back flushed again. I plan on washing them out with on/off or muriatic acid. Waiting for new end caps now. I will post some pics when completed.
35fountain is offline
Old 08-25-2015, 08:55 AM
  #84
I would trade places with any of you Fountain guys when it comes to bilge clearance. That b!tch I work on leaves me laying across the top of the carburetor if I have to do seawater pump service. The only way I have that kind of room in front of mine is if I take the side panels off the cockpit and slide the rear seat forward about 3 feet. In fact, I have installed wing nuts on the side panels so this is an easy operation. Tired of standing on my head!
Glad you found your problem. How refreshing when it turns out to be something simple and inexpensive - a rarity in the HP boating world.
Budman II is offline
Old 08-25-2015, 08:56 AM
  #85
35fountain's Avatar
Originally Posted by MILD THUNDER
35 Fountain with bravo's should have plenty of room in the bilge for strainers. Here is a picture of a 35 with Speedmaster drives, and transmissions, which move the engines forward about a foot. Still plenty of room.
Neat job, What brand are they?. I also notice different fuel filters
Old 08-25-2015, 09:00 AM
  #86
35fountain's Avatar
Originally Posted by bcfountain
hahaha,,,,and I thought I was the only one who had that problem.not to mention how many times I have gouged my back on it.
Isn't the fire extinguisher a little too low to put out a fire [ATTACH=CONFIG]544608[/ATTACH]
Old 08-25-2015, 11:03 AM
  #87
Registered User
bcfountain's Avatar
the idea is when it does go off it fogs the engine compartment with that stuff that's in there that it starves the fire of oxygen.
bcfountain is offline
Old 08-25-2015, 06:52 PM
  #88
35fountain's Avatar
[ATTACH=CONFIG]544629[/ATTACH][ATTACH=CONFIG]544630[/ATTACH] Got them pretty clean with high pressure water. A brazing rod and some muriatic acid.
I'm wondering what the water pressure is going to be now...Its amazing it was at 17lbs with a clogged cooler...
Attached Thumbnails Oil temperature issue-20150825_160044.jpg   Oil temperature issue-20150825_160058.jpg
JanTore (03-09-2023)
Old 08-25-2015, 08:08 PM
  #89
Looks great
drpete3 is offline
Old 08-25-2015, 09:17 PM
  #90
Probably back to what the factory test sheet says.
Cole2534 is offline
