502 Procharger fuel system setup problem
I have a 2000 502 mefi 3 with a m3sc procharger setup. the boat is new to me this year, and I have had issues with the fuel pressure going to high on me since ive had it. With the ATI boost referenced fuel regulator, it had very inconsistent pressures and would sometimes go up to 70-80lbs+ of pressure. I replaced this with an Aeromotive regulator followed by a Bell boost referenced regulator and have had similar problems, including where I can't adjust it below 70lbs of pressure even at idle. I'm now pulling the engine for a rebuild and want to have this working correctly when it goes back in....
Attaching a diagram of my current setup. I realize the return from should be run back to the tank and not the input to the pump, and will change that, but don't believe thats causing my current issues. Hoping eddie young, articfriends, or anyone else will have some ideas for me. http://i.imgur.com/0hpR4GW.jpg |
get rid of that boost-referenced regulator and tune the mefi3 for boost. Done. You'll never get the Bell regulator, or any other boost-ref for that matter, to remain consistent. Been there...did that.
Originally Posted by Griswald
(Post 4347221)
The issue is that it's returning to the suction side of the pump. I have been running boost dependent regulators with a returned system for a few years now and it's always the same. I have dash mounted fuel pressure gauges so I look at them all the time.
Where are you taking pressure?
By your diagram, there is no regulation to what you're referring to as the end port. If that's straight out of the pump that seems like an issue to me. FWIW - I ran the return to the inlet of the pump for years without issue. Not saying a return to the tank isn't the right way to do it, but certainly not causing the issues you describe. |
(Post 4347233)
I edited my post - re-read
Mine was never super consistent with it looped back they to the pump.
(Post 4347233)
Originally Posted by indysupra
(Post 4347241)
| All times are GMT -5. The time now is 04:30 AM. |
