Freshing up a pair of 420's gen4
The engines are stock 420 gen4 big blocks ,Both engines need cams, is there a better updated cam Then using the stock ultradyne 288/296 -h12 cam.
231/239 550/575 112 I was thinking since that's a 25 year old setup there could be something better ,I talked to someone at Bullet he couldn't answer that question but he could grind that same cam in about 2-3 weeks out I want to stay w/ the hyd flat tappet cam Thanks |
Upgrade to roller cams, it's a tad pricey but worth it.
If you can swing it. Look into getting a set of AFR 265 heads and talk to Bob Madera about cam selection. First off the head will pull 150lbs out of the back of you boat which is a good thing. They flow much better than anything you could do to your current heads which may have cracked exhaust seats. Talk to Bob he is a wealth of knowledge.
http://marinekineticsonline.com/ |
I just want to change cams some people say that UD cam was to big for the 420 it hurt performance , I can get the same cam built at Bullet just don't want wait 3 weeks if there is something better out there
I thought they had a crane #132561 cam originally, and that cam is still available off the shelf. There may be better flat tappets out there, but I don't know what they would be.
Your right they did but Mercury changed to the ultradyne 288 -296 cam toward the end of production of the gen 4 block
Originally Posted by 2stick
(Post 4350049)
http://crane.carshopinc.com/product_...d/16042/132561 I believe lunati is carrying that original 440HP cyclone cam, and possibly "elgin" cams. Calling them would be a good idea. http://www.summitracing.com/parts/lu...make/chevrolet |
wisconsin, so no salt, but those heads rot thru at the exhaust guides with fresh water too. blocks are pretty tough, but those heads are at the end of their lives.
| All times are GMT -5. The time now is 12:03 AM. |
