-   -   New gauges how to? (https://www.offshoreonly.com/forums/general-q/330389-new-gauges-how.html)
Scarab2222 09-02-2015 03:23 AM
New gauges how to?
I wanna put new gauges in my boat its a 22 scarab it has teleflex gauges so.im gonna put in some sierra arctic gauges. Will the wires there be fine or do i need to rewire? My fuel.gauge does not work.so i was gonna buy a new sending unit which teleflex has a universal one. Can i use the wires for that since thwy at already there? And my trim gauge doesnt really work so if i need a new trim sending unit do.i have to.remove the drive?
87MagnumII 09-02-2015 07:22 AM
Everything should wire the same, including the wires to the fuel sending unit. The back of the tach will probably have a switch to select 4, 6, or 8 cylinders. If the trim gauge isn't working it's probably the trim sending unit. It is on the back of the boat on the gimbal housing. The limiter is on one side the sender on the other. They look like two round pod type things. You may be able to clean up the contact area and get it working better
phragle 09-02-2015 09:21 AM
Do ONE gauge at a time and you should be fine. the only hiccup should be if you use the new livorsi gauges that have the connectors you have to splice in.
Cole2534 09-02-2015 09:38 AM
Those use Deutsch DT series connectors, top of the line hardware. If you're going to use those you'll be money ahead to buy an Amphenol AT series terminals kit, they're interchangeable but much cheaper and perfectly sufficient for the task at hand.
Scarab2222 09-03-2015 11:36 AM
I have to use bog gauges like.45/8 so im thi.king of.using autometer from ke performance.com do these need special connectors or anythig?
