Hydraulic Followers best?
which are the best hyd followers for a bbc gen 6 ? my builder told me Jesel but they dont do hyd once apparently
any one ? |
Morels.crane.comp cans.howards and the Johnsons
All good lifters Just make sure the clearances are in check |
If it is under.580 lift, factory GM.....
Originally Posted by Baldie
(Post 4357869)
Pretty sure Johnson makes GM's.
For what its worth Teague uses Johnson and tells me they are the best. Teague used Johnson short travel, oil hole in my 1250 rebuilds. |
I am using the factory GM's at .625 lift with no issues. 170hrs now and still going strong
I have 632 lift
Are these Rollers? Proper spring pressure is a big factor on how long they live. If the roller is allowed to leave the Cam Lobe at any point then the life expectancy is greatly reduced...
Originally Posted by fastdonzi
(Post 4358010)
Johnson uses a .700 wheel, morels use .750, and some larger diameter body lifters, even bigger. You should talk to your cam company/grinder, and ask what lifter wheel diameter, the camshaft was designed for. |
Is this a good time to bring up the subject of oil and oiling too ? Uh, oh.
Originally Posted by SB
(Post 4358188)
I used to think what made a cam choice the best, was its dyno numbers. I now look for a cam, that won't beat my valvetrain up in a short time, just to make an extra 20hp. . |
Originally Posted by MILD THUNDER
(Post 4358195)
yes, lol. And probably a good time to discuss the effect of lobe lift vs duration, acceleration of the lifter, .006, .050, .200 duration numbers, and how one lobe can beat the snot out of a valve train and need big spring pressure, vs another lobe, that will be easy on the valvetrain, and not need excessive spring pressure. Like for example, a .410 lobe vs a .370 lobe, on a 240* deg cam lobe, and what the larger lobe does to lifter motion. .
I used to think what made a cam choice the best, was its dyno numbers. I now look for a cam, that won't beat my valvetrain up in a short time, just to make an extra 20hp. . Some companies inverse ramps are kept in control...but how ? We can't tell off a sheet of paper right ? Also, how well lobes are machined can be a big factor. Valvetrain weight, rocker arm ratio vs lobe design, etc,etc,etc |
(Post 4358195)
Good points. I dont think there is much getting around the negative aspect, of increasing lobe lift, without increasing duration. At some point, things become an issue.
There must be a reason, competition cams, crane cams, and many others, do not make short duration, high lift, hydraulic roller, Marine, or endurance profiles. When looking thru any of their catalogs, anything "marine", or "endurance racing", with durations of say, 230-245ish range, .370 is about the max lobe lift they will run, including mercury marine. I've seen alot of custom cams lately, sporting those kinds of durations, but with .400+ lobes, and .680+lift. Crane, comp, and many guys (including myself), have ran those .370 short duration sticks for years, with 165/450ish spring pressures. But the guys with the big lobes, are running 225/600 spring pressures. I wonder why that is. Probably, because if they tried less pressure, the lifter lofts, valve train fails in short order. I like new stuff, but sometimes going with whats been proven, works better! I have yet to see a guy running these .400 lobe deals, come back after 300 hours, and say how they've never had a valve cover off of it. It very well could happen, and if so, maybe then I'd try it. |
Back in the 90's, lift at/near .600" w 1.7 rockers was extreme for bbc in cars for everything but solid rollers. Even when talking near 250-260 at ,050"
We've come a long way...haven't we ? |
(Post 4358214)
Solid FT and HR
(Post 4358206)
How would you feel with a .356 lobe with only 218° at .050", 268° at .006" and 143° at .200" ? Yes, it goes 6k or so a good amt.
BBC blocks notoriously have lifter bores not indexed correctly. That poor roller wheel and what that does to stability.
(Post 4358217)
I would say that is towards the aggressive side of things as far as valvetrain/lifter acceleration. Certainly not outlandish, but not exactly a stock 502 mag cam either that might go 1000 hours without taking a valve cover off lol
(Post 4358221)
So, .605" , 218 at .050"lobe is milder than say .650" or so 240 at .050" lobe ? How can you tell ?
I have a question for you mild thunder(or anybody else that wants to chime in),even though I should have checked before I swapped and should really ask the builder I got the lifters from.i went from morel lifters to Johnson lifters and kept everything else the same as my original set up.you mentioned wheel size difference between the johnson and morel lifters.i had some "problems" last fall/winter.redid the motor,same everything just swapped lifters.im going out this weekend to check top end,wot speeds etc.does the difference in wheel size effect performance?i guess the real question is would the engine horsepower output etc. be the same from one lifter to the next?do you know?i know I should have asked the builder but didn't think about it until I started reading about them on oso.
Originally Posted by hickle44
(Post 4358254)
Curious to see what the experienced hands have to say. |
Yes, it will alter valve timing....not much...but it will. It should not move the speedo. I'm sure MK's has a spreadsheet on this.
=========================================== On a totally different subject, A larger wheel will rotate less times for rolling same distance...no ? |
the motor has been together for this whole season have had no problems at all.put around 15-20 hours on it.doesnt sound quite the same and it seems to run just fine.could just be in my head.
(Post 4358359)
Its always a good idea to talk with your builder or cam guy on this stuff. And , nothing wrong with getting a second opinion, from another valvetrain expert. Talk to someone who does this stuff day in and day out, designs lobes, grinds cams in house, has been involved in lots of spintron testing, etc, and understands the importance of a marine endurance setup. Key word, endurance. A half dozen dyno pulls, doesn't equal success. 300 hours in the field, doing poker runs, without taking a valve cover off, is a better testament to the setup. How many times does a lifter fail, and the lifter gets blamed. How many times does a rocker fail, and the rocker gets blamed. How many times does a valve stick, or come apart, and the valve gets blamed. The ultimate goal, is to not have failure. Period. When engineers at general motors, Ford, chyrsler, toyota, whomever, design a valvetrain, they look at the big picture. It has to do lots of things, make power, be efficient, meet emissions, work with EFI, idle good, and much more, but the most important thing it has to do, is stay together. |
(Post 4358422)
.When engineers at general motors, Ford, chyrsler, toyota, whomever, design a valvetrain, they look at the big picture. It has to do lots of things, make power, be efficient, meet emissions, work with EFI, idle good, and much more, but the most important thing it has to do, is stay together.
Almost everday I run into a "Why the f*k did they do that." Yeh, it's a tough job being an engineer or what have you for a car company, but there are plenty of things, especially now a days, that will shock you. Great current example: The Germans make you believe they 'over engineer' their cars.........I never bought into it, and now the world doesn't either. |
(Post 4358353)
(Post 4358425)
I used to think that.........when starting out.
| All times are GMT -5. The time now is 03:21 PM. |
