-   -   Need Cros-reference help for a hard to find part (https://www.offshoreonly.com/forums/general-q/331156-need-cros-reference-help-hard-find-part.html)
BBCLiberator 09-27-2015 09:29 PM
Ok -- I need a fuel pump for an OMC, today my hydraulic lift came loose and smashed into my pump and broke the connector. Thankyou, chinese cotter pin, or the whack job who installed it (me)
Original OMC 987701 which is superseded by 3850818 (Volvo Part #) -- also hard to find.
Sierra has this part: https://www.dropbox.com/s/gnyta8y5vv...27.01.png?dl=0 -- This should be what I need as I have a 92' Mark V 502, however the part #'s I know about (listed above) are not cross referenced.
Anybody able to tell me if this is what I need??? I guess what I am asking, can anyone tell me if 3850818 and 3850810 are compatible?
I do know the pump on the boat has an impossible to find male-male fitting that took forever to find. I understand it's just a pump and I will patch something together if I need to, but I'd like it to drop in.
Thanks for the help!
BBCLiberator 09-27-2015 11:59 PM
Apparently that will work -- it is cross-referenced on another site.
http://www.wholesalemarine.com/elect...FQooaQodrGIA1g
Hell, Amazon even had it prime...http://www.amazon.com/Sierra-Interna.../dp/B000N9HZS8
FIXX 09-28-2015 02:33 AM
fwiw,,the electrical connector will clip back on..they are removable unless you broke the pins as well...when you get the sierra pump you will have to reuse your brass fittings,just replace the orings on them..make sure you get the rite pressure pump..i had a customer that thought he would save money and ordered the pump off amazon and he got a high pressure pump for his carberated engine..he filled the engine with fuel and hydrolocked the engine,busted the starter and filled the crankcase..
BBCLiberator 09-28-2015 06:26 AM
yeah the pin sheared off and cracked the clip in 1/2 - I was hoping I could just buy that....thanks for the advice, I'll make sure I check it out!!!
BBCLiberator 09-28-2015 01:42 PM
Better yet, the marina had an extra electrical clip just laying around and gave it to me, I fixed it in 20 seconds on my lunch break, problem solved.
How annoying that you can't buy the clip separate from the pump...
BUP 09-28-2015 06:10 PM
You will need to post the OMC model number of the engine for help getting the correct fuel pump
BBCLiberator 09-28-2015 07:25 PM
Problem solved...if I look up the part, it shows what model it's available on usually. But I'm not a part guy either.
