540 engine vacuum question >
Old 10-08-2015 | 02:07 PM
Default 540 engine vacuum question
I am wondering what others with a mild NA 540 see for vacuum while at idle. I'm seeing 10-11 inches of vacuum. This is low per stock standards but not sure about my engine. 540CI, 9.2-1 Compression, Dart single plane intake with Crane full roller setup. Thanks.
Mach80 is offline
Old 10-08-2015 | 02:19 PM
I'm no pro, but IIRC your cam will dictate the amount of vacuum an engine will see. Lift, duration, LSA and valve overlap will all play a big part in how much vacuum an engine will produce.
Jonesyfxr is offline
Old 10-08-2015 | 03:12 PM
bck's Avatar
bck
Charter Member#568
I'm pretty sure mine were similar to that. Then they blew up
Straight bottoms and flat decks
bck is offline
Old 10-08-2015 | 03:28 PM
GPM
It would help if you posed the cam specs,
GPM is offline
Old 10-08-2015 | 04:34 PM
SB
camshaft specs vs engine cid, ignition timing, intake manifold (dual vs single vs tunnel ram), and idle rpm are your largest contributors to intake vacuum.
SB is offline
Old 10-08-2015 | 07:44 PM
I wish I had the cam specs. Bought the boat from someone that has no idea what they had.
Mach80 is offline
Old 10-08-2015 | 08:09 PM
GPM
That sucks,
GPM is offline
Old 10-18-2015 | 07:24 PM
Both my 580 solid rollers fairly heavily cammed are 10" at idle. 260's-270's .700 plus lift.
Eliminated572 is offline
Old 10-18-2015 | 07:28 PM
and then if your carb/s are out of whack,remember adjusting idle while watching the vacuum gauge for the highest reading.
sutphen 30 is offline
Old 10-18-2015 | 11:19 PM
Thanks, seems like mine is mostly normal.
Mach80 is offline
