-   -   Inteior Vinyl Surface Mildew Remover (https://www.offshoreonly.com/forums/general-q/331563-inteior-vinyl-surface-mildew-remover.html)
Tractionless 10-12-2015 04:33 PM
I did a search and came up with the following products. In your opinion what would be the best to clean the mildew in the pictures below and keep it from coming back? Note there is no water intrusion present, just mildewy from sitting over 1.5 yrs. in a high humidity environment and closed up.
Spray Nine (Marine)
Yacht Fresh
Awesome Orange w/Green Scotch Bright Pad
Roll Off
Vinyl Sauce
Gogo Orange Pumace
X-14
https://im1.shutterfly.com/media/47a...D550/ry%3D400/
Thanks!
GLENAMY 242SS 10-12-2015 04:38 PM
DON'T use scotchbright pad it scars the vinyl.
I found "StarBright Marine Mildew Remover" to be the best. Also at the Dollar store Amazing works perty good for a buck.
Griff 10-12-2015 05:43 PM
25% Bleach and water mix and then let bake in the sun.
Flightplan 10-12-2015 05:46 PM
StarBrite and sun has worked for me. sun alone will surprise you.
Ballistic Beak 10-12-2015 05:54 PM
Marine Spray Nine
donzi matt 10-12-2015 07:33 PM
Be careful using bleach around any stitching, it will erode the thread and you will end up with separated seams.
bck 10-12-2015 10:03 PM
A guy I know that makes vinyl interiors (good ones), told me to use Tilex. I used it with Mr clean magic erasers and it cleaned up dirt and mildew beautifully. I was worried about the tilex, but it doesn't seem to have done any harm that I can tell.
Full Force 10-13-2015 06:08 AM
Magic erasers are bad I am guilty once or twice to get a good cleaning but not a good practice for sure regularly
bcfountain 10-13-2015 07:35 AM
red thunder.its made by a company named mallco.dilute with water.works great on stiching .
Tractionless 10-13-2015 10:59 AM
Good info. unfortunately I won't be able to remove and place in the sun as they are interior parts and will stay in place during and after cleaning.
