-   -   deciphiring Crane gold rockers (https://www.offshoreonly.com/forums/general-q/331917-deciphiring-crane-gold-rockers.html)
Rambocj7 10-25-2015 11:13 AM
I have twin motors that both have crane 1.7 rockers. Each set has a slightly different part number at the end %. What does that mean? One set is -10 the other set is -5. It seems that pushrods are different lengths because of this too. Everything else is identical in each motor (cams, heads, lifters etc). I need a few replacement ones and I don't see any mention of this last part number when looking at the specs, only the ratio.
http://i1225.photobucket.com/albums/...psrqihqrkv.jpg
http://i1225.photobucket.com/albums/...psj2j0bhmw.jpg
14 apache 10-25-2015 11:32 AM
Think that is the date they where made .
Rambocj7 10-25-2015 11:43 AM
I sort of thought that until I saw difference in the length of the pushrods of each motor. All other things being equal, why would I have pushrods of different length? 9.250 vs 9.300 for the longer ones. The short ones are the same in both motors at 8.30 in length.
MILD THUNDER 10-25-2015 12:59 PM
Things like heads being milled, decks being milled, valve stem heights, lifter seat heights, camshaft size, etc can have an effect on what is the optimum pushrod length. Or, simply, whoever built the engines, happened to have a spare set of pushrods to stick in something. Hundred variables here.
bck 10-25-2015 02:35 PM
I have ones marked -7 and - 10. I'd like to know also.
turbo2256b 10-25-2015 05:41 PM
Dont know if its the same deal but Fords canted valve heads used 1.73 rockers. Until a few years ago when one purchased a set of roller rockers for them you were actually getting BBC rockers they were marked 1.73 -.03. ( at least on Crane rockers) SO NOT ONLY DID you loose lift but valve train geometry was wacked to as valve angles an such were different from a chevy.
SB 10-25-2015 09:29 PM
Many have different symbols or letters before the - . Even with Part #'s being the same.
Good question for someone who worked/works at Crane.
bck 10-26-2015 04:10 AM
Mine all say 13-170. Then below that some have the -7 or -10. They were being used on Chevy mark 4 rectangle ports
jeff32 10-26-2015 06:11 AM
Are you having engine problem? If i recall your engine were 632 cubic inche right?
Rambocj7 10-26-2015 08:31 AM
No, I've got a pair of 540s with vortec blowers. Motors ran fine, but doing top ends right now (It's amazing what you find out with a leakdown test).
