-   -   bb cylinder heads :how to choose? (https://www.offshoreonly.com/forums/general-q/33215-bb-cylinder-heads-how-choose.html)
timucin 09-18-2002 05:17 AM
how do I choose cc's?
bigger better?
which one do I need for 750-800 hp on top of 540 cu in?noncharged
thnx
Dennis Moore 09-18-2002 11:24 AM
Which heads?
Have you decided what RPM your are comfortable with? 4800, 5300, 5600, 6000?
How much compression are you running? Premium fuel? Race fuel? Is the fuel going to be available where you go boating?
Carb or EFI? Do you need a choke on the carb for easier starting?
How big is the boat?
Do you need extreme amounts of torque or just high horsepower?
How about adjusting the valves and replacing worn valve springs on a regular basis. Are you willing to do this after only 50 hours of running time?
Do you have to idle a long way in a no wake zone?
Is the engine going to see constant high speeds or is it very seldom going to need full power?
How quiet does the engine have to be? Are you going to need mufflers?
Salt water corrosion problems? Aluminum or cast iron heads?
Closed cooling or standard cooling?
These questions (and others) need to be answerd before you make a cylinder head selection.
Sincerely
Dennis Moore
FAMILY AND PERFORMANCE BOATING MAGAZINE
timucin 09-18-2002 05:16 PM
dear Dennis;
5600
94 octane pump gas
carb -no choke
40-v bottom -hi-tec light boat
horsepower
no
yes
full throttle as much as possible (3000 rpm's cruising)
no
salt water but no corrosion problem because we rebuilt it every season
standart
Do you think I can receive around 750 hp under this combination?
thnx for your help;
Dennis Moore 09-18-2002 08:12 PM
Heads?
Dear Timucin,
When you get up into the 750 horsepower range you will have constant valve train problems. This amount of power requires a camshaft with an almost square lobe. You really have to open the valve fast, open the valve high, hold it open for a long period of time (duration) and close it fast in order to let enough air/fuel mixture into the engine to make that kind of horsepower.
The camshaft lobe literally smacks the lifter and puts huge side pressure on the lifter body. The lifter base (roller) has extreme downward pressure on it from strong valve springs. This requires, at the very least, solid roller lifters. If you couple solid lifters with the extreme expansion and contraction of aluminum heads the valve lash will move around constantly requiring constant valve lash adjustments (especially with long periods of engine idle and extreme engine temperature fluctuations).
The stiff valve springs will fatigue very quickly while the engine is running and when the engine is not running some of the valves will be open and some will be closed. The open valvesprings will take a set and lose tension. Valve spring replacement will become necessary every 50 hours or so.
Valve seats will have to be inspected and touched up often.
Mercruiser High Performance suggests that the complete valvetrain be rebuilt every 50 hours on the 900 SC.
Your horsepower is going to be limited by the amount of maintanence that you are willing to perform on the valve train.
Comp Cams has some new hydraulic roller lifter camshaft profiles made just for marine engines. Because they are hydraulic you won't have to be constantly adjusting the valve lash. These marine camshafts also have slightly lower valve lift than a typical high performance (automotive racing) camshaft. The lower lift is compatible with lighter spring pressures (less spring replacement). The problem is that you are not going to make 750 horsepower with these more sensible camshafts.
Using the Comp Cams Xtreme Marine XM296 HR camshaft, the World Products 345 cc CAST IRON Merlin Marine head, flat top pistons with a tight quench, the World products MARINE single plane intake manifold and Holley MARINE Dominator carb, a CMI header exhaust and a good induction style ignition you might have around 600 horsepower at 5,600 rpm with good pump premium gas. The engine would be fairly reliable with oil changes required every twenty hours and valve train maintanence every 100 - 150 hours (pulling the heads).
You should also use a full thermostat cooling system for stable engine temps and an oil thermostat so the oil temp will stabilize and reach at least 200 degrees soon after starting the engine.
Hope this helps someone!
Sincerely
Dennis Moore
WETTE VETTE 09-18-2002 08:48 PM
Good points on the solid roller stuff, but my experiences have been very good. The cam I am running now has 272/280 duration @ .050" lift with .714" lift on a 112 + 4 installation. I have 22 hrs. logged on this motor. I check the lash every 7 hrs or so and haven't had to re set the lash yet. I run Dart 325 pro 1 aluminum heads, with Jesel shaft rockers, and I hardly ever idle for more than a minute or so. If you like to turn wrenches solid cams MAY be for you. If you would rather just go boating, stick with the hydraulic variety. I like wrenchin, so solid it is. Hey Dennis how much HP is my little 496 makin. The heads are fully ported with 2.3 intake 1.88 exh. The cam mentioned above with 13.2:1 compression. It breathes through a Merlin intake and a Nickerson 1050 Dominator with CMI E-tops. It likes to run 5900 to 6300 RPM and pushes my Baja 210 into the upper 90's on GPS when the air is cool. I ran out of money for the dyno!!:rolleyes:
Craig
Dennis Moore 09-18-2002 09:47 PM
Bitchin engine!
Wette Vette
Sounds like a great combo! I really like 496 engines (non siamese bore), you must be at LEAST 560- 590 horsepower @ 6,000 rpm don't you think? I know that 530 horsepower at 5,800 rpm with a much milder cam is relatively easy with a 509 (850, dual plane, Merlin Ovals, 9.5:1, 234/242 duration). Big money for the Jesel shaft rockers but I bet it is one of the reasons that the lash stays on specs. What amount of full advance and octane gas do you run with the big compression ratio? (the torque must be awesome!)
Sincerely
Dennis Moore
timucin 09-19-2002 12:36 PM
thnX Dennis!
turbo2256 09-19-2002 02:00 PM
I agree with you Dennis never liked the siamiseded blocks for endurance applications they suck
WETTE VETTE 09-19-2002 05:52 PM
The 13.2:1 compression 496 burns the official fuel of NASCAR. 110 octane leaded Union 76 race fuel. The motor seems to like 36 to 38 degrees and I run the timing locked in. My boat went 65 MPH with a stock 7.4 L, 330 HP so I would guess the HP to be at least 650 to push it 97.8 MPH, but who knows. The torque is awesome!!!
jdnca1 09-19-2002 06:40 PM
650 :rolleyes: :rolleyes: .....+100;) :cool: Now we're getting close!
KAAMA 09-21-2002 09:23 PM
Just curious...
What other choices of non-siamised blocks do we have that are beyond 496 cubic inches? What suffers in a siamised block that is used for endurance purposes? Thanks
Dennis Moore 09-21-2002 10:06 PM
Siamesed blocks
I don't think there is much wrong with using siamesed blocks for horsepower production. But I think that when it comes to reliability in a regular production engine it would HAVE to be better to have a coolant jacket surrounding the cylinder. It would certainly make the water flow through the engine easier and without as many steam pockets.
I have never had any problems with 502 engines but Chevrolet did redesign the head gaskets for an improvement in cooling (now there is a left and right).
Engines would be a lot more compact with siamese cylinders and I would think that they would be more common if there were no drawbacks.
Chevrolet went to a lot of trouble to design the new 496 without using a siamese block. There must be some good reason why!
Dennis Moore
timucin 09-22-2002 02:08 PM
himmm.......
I think Im gonna need a charger for 600+'s
