-   -   Go To Bilge Pump and Float Switch? (https://www.offshoreonly.com/forums/general-q/332475-go-bilge-pump-float-switch.html)
Tractionless 11-15-2015 07:32 PM
I have a '96 Baja 302 diagnosed by the inspecting mechanic as having a constant on Rule Mate 1100 gph bilge pump with internal float switch. After reading some online reviews of these units the sticking has shown to be an issue within 1 yr. of installing a new assy. I prefer not to install the same known "junk". Is there a better option whether the float switch is internal or external, and if external which float switch to use?
Thanks!
Keith
murfman 11-16-2015 05:34 PM
Jabsco 36600 is the one I'd trust, its rebuildable, however the rebuild kit is more than most standard bilge pumps.
Tractionless 11-16-2015 06:11 PM
Thanks for the info. but YIKES I'd like to stay away from a belt drive. :eek:
bck 11-16-2015 10:27 PM
Here's your switch. Never an issue.
http://www.tefgel.com/contain.php?pa...mpswitch_price
MILD THUNDER 11-16-2015 10:30 PM
The lovett pumps in my fountain are belt drive. They have been great .
bck 11-16-2015 10:34 PM
Do you have a pic of that set-up?
