-   -   Latham Power Steering Reservoir (https://www.offshoreonly.com/forums/general-q/33249-latham-power-steering-reservoir.html)
DaveHam 09-18-2002 02:50 PM
Does anyone know of a replacement for the plastic oil reservoir that sits on top of the stock power steering reservoir. Mine is leaking and I don't have a suitable place to mount the newer unit from Latham. Besides it's $400.
DaveHam :mad:
blown formula 09-18-2002 04:28 PM
Hi Dave !!
Are you speaking of the blue topped/clear side canister for the steering reservoir? I would think you could find new o-rings to put in the old unit....... It appears to be rebuildable, isn't it????
(am I looking for future trouble now???) My Formula is a '97 312.... yours is what?:confused:
DaveHam 09-18-2002 06:09 PM
Blown Formula
Mine is a 97 312 also with Whipplecharged 454's. The reservoir I'm talking about is black plastic and sits on top of the stock PS pump.
DaveHam
blown formula 09-19-2002 08:47 AM
Dave,
Yours is different then. Mine is the Latham model with anodized aluminum top & bottom & has clamping screws in it w/o-rings. So I guess this must be the $400.00 version!! Mine is also seperate from the pump & connected with hoses and a LARGE Latham billet filter also. It mounts to a bracket on the starboard side of the starboard engine....
DaveHam 09-20-2002 08:08 AM
Blown Formula,
Mine is apparently the older style. I don't have room to mount the newer style because of the Whipples.
Dave
PS Did you get your transducer mounted yet?
Audiofn 09-20-2002 08:14 AM
Dave check out the Power Steering for 500 bucks there may be some solutions for you in there. One guy got his stuff from a speed shop :D:D
Jon
Scott 09-20-2002 08:29 AM
Just something to think about
Do you have to have one? I have been running mine Latham dual ram setup for a year with just the fluid in the PS pump. Stays cool and not a drop of fluid anywhere! I have to wonder the true purpose of the add on resevoir. Are they still necessary on todays systems? Will I have trouble someday? I doubt it;)
blown formula 09-20-2002 08:50 AM
On my last boat, no reservoir was needed either. I believe it has to do with the total volume of fluid required in the system. A filter should also be used.
Dave, are you running the stock exhast? If so, a bracket can be made to hold it from the riser bolts or the throttle cable bracket bolts. Also a braket could be fabricated from the bolt holes above your steering pump. A whipple is pretty big, but manageable. Another reason a PC is good!!:) Just kidding!! It is also not required to be mounted to the engine, just be mounted higher than the pump reservoir. Mount it remotely!:)
