Cross over kit
Hi
Im going to take my water pump off , who makes the best crossover kit with a thermostat Thanks |
I like this one http://teaguecustommarine.com/em0011...th-bypass.html, except that I'd order it with the thermostat housing to have AN fitting outlets.
JMPH,may i ask why you are removing the circulating pump?
I was looking and this one it catches my eye it's made by Diamond performance # 16634 with thermostat , does anybody use the Teague or Diamond Performance crossovers ?
If going with a thermostat outlet with AN fittings, make sure the fittings are big enough. Most mercury and aftermarket manifolds are fed with a minimum of 1 inch ID hoses. A -12an is substantially smaller, and may cause high water psi, or inadequate cooling of the exhaust/engine due to less flow. A -16 is still smaller than what mercury used
Originally Posted by mike tkach
(Post 4380002)
Originally Posted by MILD THUNDER
(Post 4380005)
what engine do you have?
I've been contemplating doing this also but am concerned about hot spots in the back of the heads. Has anyone tapped into the rear of the heads to run a line back to the front?
Originally Posted by turbofox54
(Post 4380011)
| All times are GMT -5. The time now is 09:22 PM. |
