Pulling a motor from the flange of a 177 wieand
Is the 177 wieand blower carb flange strong enough to pull a dressed big block?
I would NOT do that.
Double dog dare ya... Take vid and post here.... Like upon next start up if doesn't rip the blower off the first time.
straight answer,NO.
Thanks guys, I didn't think so
The tolerances inside the supercharger, are very tight. The last thing you want to do, is distort the aluminum case.
There are lots of other ways to lift an engine out of a boat. My favorite, is either a pit pal sling, or, four 1 inch nylon lifting straps, one at each corner of the heads, if no lifting rings on engine. |
The SC is only torqued down to about 15# and the bolts holding it only go into an aluminum manifold less than an inch.
As was said..........NO |
Originally Posted by MILD THUNDER
(Post 4380521)
. This is what I'd be also be afraid of. |
hell no.
| All times are GMT -5. The time now is 09:37 PM. |
