Lean, or excessively retarded timing will do it too.
What would be excessively retarded? I had it at 32-34* all in. I want to say it was 34 but might have went 32.
That's not excessive.
Oil therm , block bypass to therm housing, take valve out of thermostat , #10 lines,big coolers , transom water pick ups
New strainers, bravo pumps, keep block pressure 25 psi or less. Let er rip |
I run 34 degrees timing and a conservative 650
Is that supercharged or NA?
Originally Posted by KAOSS
(Post 4385716)
Cause of engine damage has been discovered. When I brought the heads in, my guy said the motor went lean. The beating the bearings took also suggested the motor went lean and detonated. Well Here my friends is the answer. The most expensive vacuum cap ever!!
http://i880.photobucket.com/albums/a...IMG_2334_1.jpg |
Originally Posted by 79formula
(Post 4386146)
Ouch!
Yup. I put new head gaskets in the motor 50hours ago. The motor looked good inside at that time. I only pulled the motor to switch to inconel valves. I wonder how long I had been running like that.
That totally sucks - are you doing the rebuild or a shop?
Ryan |
That's a good argument for keeping a wideband hooked up all the time.
Anybody running this unit from Innovative DLG-1: Dual Lambda (AFR) Gauge Kit - If so do you like it?
Steve Auto and Machine in LittleValley NY is building the shortblock. Just got my heads reconditioned. $800 for heads re-done with manley Extreme Duty valves.
Originally Posted by Ballistic Beak
(Post 4386365)
Ryan |
The build so far:
Block decked, line honed with ARP main bolts, and bored .060 over New Melling 10778 HV pump Stock crank had to be turned .010/.010. Stock rods rebuilt with ARP bolts. New L2399 pistons. New Crane 134561 cam and lifters. Heads received all new seats. New Manley Severe duty 2.19 intake valves. New Manley Xtreme Duty 1.88 exhaust valves. Oil cooler, hoses, and filter mount from HP500. Mercruiser 525sc Blower, carb, and intake manifold. DUI distributor. It should all be assembled in the next few weeks. I am also paying the money to have it broke in on the dyno and tuned on the dyno. Ill post pics and videos as I get them. I hope my 242 runs 75. |
Money well spent on the dyno! Keep up the progress!
Since Steve is building the motor, he quoted me $300 to throw it on the dyno and tune it. I felt that the $300 was the smartest money spent on the whole build.
Originally Posted by jeff32
(Post 4389811)
Did this boat come from Massachusetts?
Originally Posted by Fischan
(Post 4389841)
http://i880.photobucket.com/albums/a...59540007_o.jpg http://i880.photobucket.com/albums/a...55522934_o.jpg |
The heads should be done next week. The rotating assembly got balanced today. Shortblock gets assembled next week. Cant wait for summer!
Sounds like a fun engine for your 242. I used to have an '87 242 LS with 530 +/- hp and it would run 68 MPH gps. The 242 is a great riding boat for its size mainly due to its weight, because of this, it takes a ton of power to make them go fast. I ran a Mirage Plus prop that was 21 pitch at 6100 rpms,
Originally Posted by endeavour32
(Post 4392602)
I'd say you should be close to 75 mph. Honestly I don't think I would want to go much faster that that in a 242.
At 63 mph mine felt like it was running out of hull and chine walked really bad. It might have improved with 280's rather than the small bennet tabs.
(Post 4395390)
Keep us posted on progress !
Originally Posted by Matjluk
(Post 4397162)
The only unknown at this point: Fuel lines- I got a nice Earls -8an fuel line on the carb so I need to get the line from the pump to carb. I have never dealt with AN stuff before. I am hoping to get it on the dyno in february. |
Well its been a while since I have updated.
The build is as follows: Stock forged crank. Reconditioned forged rods with ARP bolts. Melling HV oil pump. TRW 2399 pistons .060 over. The heads I got are stock HP500 Carb heads. They have Manley Severe Duty intakes with inconel exhaust valves. I used a crane 134561 cam with their matching triple springs. The Blower and carb is all stock 525sc stuff. I have a few questions with my setup. According to desktop dyno compression calculator, with .005-007 deck height, 17046 Fel Pros, and 2399 pistons my compression will be 9.25-9.33. I am not a machinist so my measuring was with a feeler gauge on top of the piston. Kinda crude I know. What should my timing curve look like with that compression? What temperature thermostat should I use? I was thinking a 120 to help with the higher compression. I will be using 91octane non-ethanol only. No exceptions! http://i880.photobucket.com/albums/a...5dbdf65797.jpg http://i880.photobucket.com/albums/a...r/IMG_2444.jpg http://i880.photobucket.com/albums/a...r/IMG_2443.jpg http://i880.photobucket.com/albums/a...r/IMG_2442.jpg |
What numbers are you using for compression? Is the block bore notched? Here are my numbers;
1.2 cc .005 deck 9.5cc head gasket 1.5cc ring -13.8cc dome 121cc combustion chamber 956.3 cc swept 9.0:1 |
Originally Posted by Mr Maine
(Post 4403045)
(Post 4403036)
The build is as follows: Stock forged crank. Reconditioned forged rods with ARP bolts. Melling HV oil pump. TRW 2399 pistons .060 over. The heads I got are stock HP500 Carb heads. They have Manley Severe Duty intakes with inconel exhaust valves. I used a crane 134561 cam with their matching triple springs. Motor looks sharp.. |
Originally Posted by SB
(Post 4403106)
I hope the 'triple springs' was a typo.
Tomorrow is the big day. DYNO TOMORROW!!!!!!!!!
(Post 4403119)
Its has 2 springs and a damper spring. For regular use Crane 99893 is ok. For extended high RPM use Crane recommended 99896 springs. They were $256 vs $89 for the cheap springs. It seems like valvetrain is not the place to try to save money.
The 99896 spring is for a hydraulic roller camshaft, and will have way to much pressure. 99896 is 150 psi @ 1.900,and has a rate of 528lbs lbs/in. With your cam, it would have around 450lbs of open pressure. That will kill the cam quickly. |
Those are the part numbers Crane specifically recomended.
Originally Posted by MILD THUNDER
(Post 4415799)
I hope that was a typo on those springs.
(Post 4415805)
1 Attachment(s)
Must be some typos.
Irregardless, the 99896 is a heavy spring meant for hydraulic rollers, not flat tappet hydraulics |
2 Attachment(s)
99896 spring specs
My solid roller springs had a rate of 551 lb/in.
I recommend not starting that engine tomorrow. Sorry |
| All times are GMT -5. The time now is 09:34 PM. |
