Procharger boost 91 octane
How much boost can I run on 91 octane ?
Engine is 8.6:1 compression with Aluminum heads and an M4 Procharger.. THANKS ! Doug |
Cam specs? Intercooler?
Originally Posted by MILD THUNDER
(Post 4380721)
Just found a dynamic compression calculator.. put in 8 psi & the dynamic is 11.6:1, but what is the max for 91 octane ? Your engine summary is as follows: Bore 4.560 inches, stroke 4.25 inches, rod c-c length 6.535 inches, with a static compression ratio of 8.6 :1. Your camshaft specifications call for an inlet valve closing of 49.7 degrees ABDC (after bottom dead center). Your chamber volume is 149.66 cc's. With this camshaft your dynamic, or effective stroke is 3.70 inches. Your dynamic compression ratio is 7.52 :1 corrected for cam timing, altitude, and rod length. Your dynamic cranking pressure, corrected for cam timing, rod length and altitude is 146.67 PSI. Your dynamic boost compression ratio, reflecting static c.r., cam timing, altitude, and 8 PSI is 11.61 :1. |
I know articfriends smitty, ran something like 12lbs on his procharged 540's. Maybe he will chime in.
I'd invest in a good IAT gauge for the dash. Keep on eye on those intake temps.... |
(Post 4380727)
I'd invest in a good IAT gauge for the dash. Keep on eye on those intake temps.... How far would I have to back it down to be 91 octane friendly ?
Originally Posted by Haxbyspeed
It really depends on your combo but I agree, 14ish lbs with conventional Procharger stuff seems to be the max safe level for 93 octane. The MAT spikes quickly because the Procharger starts to produce a lot more heat as the boost comes up. If the intercooler is sized correctly, it will level off. I usually see 135-155 after a few minutes of WOT, which is nothing to worry about. I like mid to high 11's AFR, up to 10-12 lbs, and lower as the boost goes up. On pump gas the prochargers like to be a bit richer then a Whipple to make max power, and MBT is usually lower then a similar Whipple or roots combo too
Originally Posted by articfriends
IF a Prochargerd marine motor has EFI, afr's verified/tuned on water at wot, aluminum heads and compression close to or around 8-1 along with 75-80 MAX degree lake water for innercooler 12-13 lbs is easily reliable, I have ran that kinda boost for quite a while and haven't hurt a motor yet, Smitty |
On dyno when I made 1115 hp we saw 14 ish psi boost in intake (past) throttle blades, this was on 80% pump 92/93 and 20% 110 octane, I ran medium pulley at 13-14 psi on 92/93 on dyno, in boat the pulley that made 14+ made more like 13 and the pulley that made 13/14 made 12-13 roughly, I always run 93 in boat with that pulley at 8.3/ 8.4-1 compession and never logged any KR on data logger/scanner pro, even on a 5 minute /6300 rpm pull. Cam, chamber design, innercooler efficiancy, under hatch air flow, water temp to innercooler, engine block temp, timing curve, afr, etc will all have factors in how much boost you can safely run and for how long. Stuff needs to be perfect to run max boost for a given octane, off top of my head I would say 8 psi, and possibly 10/11 BUT only way I would run that much is IF you can monitor KR!
the reason I say 92/93 is we went thru quite alot of fuel on dyno, we made several trips to gas station and deliberately bought 92 instead of 93 in last couple of trips, the reason why is I always run 93 BUT wanted to see if we had KR on slightly lower gas to give some safety margin. |
I only run 6psi but only on 93, even at a decent cruise you are still in boost for a long period of time...tuning with a 02 in the boat running a must, but I would think 5-6 max w/91 but too many variables here. Why only 91 ?
Steve Brule at Westec in CA taught me a long time ago that the best indicator for boost, if you're on the dyno, is to watch the BMEP number. Depending on the fuel you're using there is a max "safe" bmep. I was dynoing a 540 pump gas marine engine with a 1471 and intercooler...we were watching the IAT's because we didn't have a fresh cold water source for the intercooler and had to use dyno water, but he was watching the BMEP's more than anything. I think he said 230-235 was about max for CA 91 octane pump gas. Engine made 1021 @ 6400 (for a small Vdrive hot rod boat) and about 32* timing, right at 10# boost. I know centrifugal blowers are a lot more efficient and should make a little more power than a roots.
Originally Posted by ezstriper
(Post 4380835)
I'll certainly fill it 93 when it's on the trailer.. Doug |
Originally Posted by horsepower1
(Post 4380851)
I think the prochargers, turbos, and screws can get away with a little more wouldnt you say scott ? |
