-   -   Engine/Outdrive Swapout (https://www.offshoreonly.com/forums/general-q/332894-engine-outdrive-swapout.html)
Pismo10 12-15-2015 11:34 AM
Remove drive, 10mins, install drive 15mins, remove engine 1 to 1 1/2 hours, double it all, etc. done it.
buckknekkid 12-15-2015 11:39 AM
Don't forget
Originally Posted by 1 MAIDEN AMERICA (Post 4384478)
Don't forget to add time for broken bolts, to clean electrical connections, change impellers, plugs, whatever, lube linkages, clean and grease splines, liquid electrical paint/dielectric grease connections, install floor/seat coverings, clean bilge, the extra guy helping remove hatch and align engine, filling stripped wood screws, the drive to the lake, launching, running, and returning to shop, looking up, ordering, checking in parts, running computer checks, set timing, fix all the crap the last hack did, and ?????
With that I'd say:
remove prop, drain drive, pull drive-30 minutes
clean bellhousing area, bellows, input/output splines, bolt corrosion-1 hour
grease everything, reinstall, fill drive-1 hour
cover/protect body/seats-1/2 hour
remove hatch with 2 people-15 minutes X2 = 1/2 hour
ready engine for removal-1.5 hours
remove engine with 2 people-1/2 hour X2 = 1 hour
clean bilge-1 hour
change plugs, cap, rotor, wires, impeller-2 hours
clean/fix misc-1 hour
reinstall engine with helper-45 minutes X2 = 1.5 hours
finish reinstalling engine, adjusting linkages-3 hours
reinstall hatch with 2 people-1/2 hour X2 = 1hour
test run engine at shop-1 hour
drive to lake, launch, park, run, retrieve, drive back-3 hours
looking up, ordering parts-1 hour
17-20 hours in about ideal conditions/same engine going back in-not too much corrosion, no broken bolts, grounds, etc, boat has fuel, owner told you about special switch under dash to start engine, trailer wiring doesn't need a special bayou connector and has air in the tires, ????
The owner and his buddy rigged a few things in less than 12 beers and oh did he tell you about the electrical gremlins?
4czn10 01-08-2016 11:32 AM
thanks Buckknekkid! i got my final bill and it was 69 hours times $125/hr = $8,625 plus $2,000 in parts. and it's still not running correctly. i have a stall out issue that needs to be fixed. and he's going to charge more for that.
After reading all your comments, i'm mad as hell and i think im going to take some legal action. ill keep you posted!
4czn10 01-08-2016 11:34 AM
Thanks Maiden!
This will help in my legal action!
seafordguy 01-08-2016 09:50 PM
These threads pop up from time to time.....
On the one hand, time can really get away from you if
You're dealing with rusted bolts, etc......
On the other hand I am not a merc trained mechanic and can singlehandedly have my drives off, crane set up, hatch off, and both motors sitting on my garage floor before lunch, and can drop them back in just as quickly with zero help from anyone....
These threads always make me think - 69 hours is almost two straight work weeks. 8-5, M-F. Seems like a LOT could be accomplished if your only job was working on a boat for two weeks
4czn10 01-09-2016 10:59 AM
There were no rusted bolts, or anything difficult about this job...in fact both motors were in the respected boats a couple of years at most, and no salt water...I'm a fair person but this makes me mad!
Mr Maine 01-09-2016 11:14 AM
69 hours would be fine if he was charging 10 bucks an hour.
At 125 an hour he should be top shelve. I'm an amateur and I pulled both mine in about 5 hours not hurrying.
4czn10 01-09-2016 11:27 AM
Thanks. I hope that any mechanics that read this will respond with their thoughts and let me know they are mechanics, so I can use this in a court of law. I don't want anyone else to be ripped off by this unscrupulous mechanic!
Thanks to anyone that is willing to help!
Pismo10 01-10-2016 02:58 PM
Crook..
Griff 01-10-2016 03:24 PM
All of the labor should have laid out prior to him working on the boats. Any additional charges should have needed your written approval.
You signed the service order and gave him a blank check. You have no recourse.
