-   -   Drives..turn IN or OUT?? (https://www.offshoreonly.com/forums/general-q/333023-drives-turn-out.html)
MILD THUNDER 12-10-2015 07:29 PM
Originally Posted by Powerquest230 (Post 4384163)
Is the transmission ratio the same forward and reverse? If so, you could run it as is, switch props and go run it again in reverse to see which you prefer.
You DO NOT want to do that. You will most certainly break the transmissions.
Full Force 12-10-2015 08:13 PM
Yea that would suck... Oops
TAStevens 12-11-2015 06:40 AM
Im a Power Boat rookie but not to motorsports....not enough clutches in the Rev pack to do that! Kind of like a Racing Powerglide
frickstyle 12-11-2015 07:54 AM
I'm confused here. Don't you just swap the drives??? 6 nuts on each side right? Should take one hour max?
TAStevens 12-11-2015 08:31 AM
yep! what were going to do!
frickstyle 12-11-2015 08:33 AM
OK, just checking. Good luck Tim, hopefully we'll both be fully functional in the Spring!
And also, that thing is gonna haul!
TylerBurich 12-11-2015 11:14 AM
Would really like to see a video showing the profile and attitude the boat runs best at on top end. Not many 311's running past mid 70's ... Sounds like you will be knocking on the door of 90!
