Piston dome cc
I have dome pistons that are advertised at +13.8cc. I put them in the bore .2 in the hole and cc them, I only get -6cc. Bore notch may take up a cc or 2.
What's up with that? So I take the piston and wrap it tight with masking tape and fill the relief to meet the dome, takes14cc. .095 dome on a 4.29 piston comes out to 22cc or so for a measured net of +7cc. Take away a cc for the bore notch and I'm back to my measure of 6. I need to set the compression, advertised -13.8 and measured -6. What am I missing? Fyi, I measure the untouched combustion chamber and it spot on 121 as advertised. |
Domes are + CC. Dish are - cc.
You'd have to make a mold of the top of the piston and then fill( liquid cc measure) that. |
or put piston to tdc, fill that,
Take that cc and add to your gasket added cc, and then add comb chamber cc , and that will all equal your total combustion area cc. Compare that to your single cylinder cid and that will equal the compression. |
Originally Posted by SB
(Post 4384192)
You'd have to make a mold of the top of the piston and then fill( liquid cc measure) that. First I put the piston in the hole .182 with a bit of grease to seal. Took 37cc to fill plexiglass on top. Calculated 43 for a net of +6cc. Tape around piston, fill with liquid to top of dome I get 7cc. Assume the 1cc difference is the bore notch at top of bore. Looks like I need to use +6 as measured not +13.8? These are a small .095 dome, no dish here. Thanks |
(Post 4384194)
| All times are GMT -5. The time now is 05:08 AM. |
