-   -   525efi - mechanical fuel pump oil change (https://www.offshoreonly.com/forums/general-q/333377-525efi-mechanical-fuel-pump-oil-change.html)
bonesmalon 12-31-2015 02:54 PM
Originally Posted by HyFive578 (Post 4389207)
Currently, I just turn the pump upside down and sideways until it all drips out but I've been wanting to do the same thing with the drain plugs. Where did you drill the hole and what size tap and plug did you use? Any pictures?
You have to pull the pump to put the drains in and there's an an obvious flat location that you'll see once you have it out. I used an Allen head plug with an oring seal rather than a pipe thread which seals because of its tapered threads. These can create cracks from stress if over tightened hence the o-ring style I selected.
imartin 01-03-2016 06:25 PM
Ok, here is my update: pulled the fill screw out for port, then stbd eng and as predicted, a fuel/gear lube mix flowed out. Smelled of gas. Syringe set up wasnt good at pulling any fluid out. It helped when it came to filling. I did fill till steady stream of gear lube coming out. I guess i did what is required maintenance.
I then started engine at boat ramp. All seemed ok, Smartcraft showed 40-42 fuel psi.
Does this maintenance impact fuel psi? My reading is within specs, so shall all pressume all is good? How/when would I know if I have a problem?
I am glad I got that gas out of there.
Thx.
bonesmalon 01-03-2016 07:58 PM
Thx.
The pressure you're reading would be the pressure created by the electric EFI pump not the mechanical one you just serviced. The mech runs about 8 psig and the electric one about 43 psig if I recall
imartin 01-07-2016 10:11 AM
Originally Posted by Griff (Post 4389109)
I've tried using a syringe with a 1/4" tube and sucking the lube out. You can only get about half of the lube out that way. The tube gets hung up.
So Griff (or anyone else for that matter), what are you using to get the lube out? (assuming you don't have a bottom drain installed).
Griff 01-07-2016 01:00 PM
I don't have mech fuel pumps anymore. That is what I did on my other boats when I had them.
I used to change impellers every other year.
I would just remove the entire sea pump and tip it on its side and let the lube drain out on the years I was also changing the impeller.
On the years I wasn't changing the impeller, I would suck out what I could with the syringe/tube and then try and force/flush new lube in.
imartin 01-07-2016 03:26 PM
ok, that's what I did with the syringe set up. I likely flushed more in than needed, but I did so until new and clean lube flowed back out....
Thanks,
PARADOX 01-25-2016 08:29 PM
What oil to use in the fuel pump? Gear lube? synt. oil? I have to do this too, but I have them off. :)
bonesmalon 01-25-2016 09:04 PM
Same gear oil you use in ur drives
