-   -   6.2 mpi (https://www.offshoreonly.com/forums/general-q/333669-6-2-mpi.html)
merkfalc 01-10-2016 08:10 PM
6.2 mpi
Hopefully this is an easy question. Can a 6.2 mpi bolt up to an old vp280? I'd like to get the reliability of a modern engine into my old chris craft and keep the performance of the original 350.
Thanks,
David
BUP 01-10-2016 10:35 PM
6.2 can if the correct engine coupler was used and make sure the input shaft going into the coupler is the correct length.
merkfalc 01-11-2016 05:57 AM
Thanks, that's what I figured. Wanted to double check.
ezstriper 01-11-2016 10:07 AM
some of the flywheels/couplers don't work with each other when comes to one piece vs 2 piece rear main seal...just watch that
merkfalc 01-11-2016 10:30 AM
Good point, thanks for bringing that up. It's definitely a two piece block going to one piece. I'll have to look into that.
BUP 01-11-2016 11:42 AM
correct above ^^^^^ and teeth location if it is top mount or bottom mount starter
merkfalc 01-11-2016 11:57 AM
Where's the starter located on the mpi? Volvo is bottom right as you're looking at it.
BUP 01-11-2016 12:03 PM
I/O's were bottom form Stock Merc apps and some inboards and or ski boats could have top mount starters - also depends on how much clearance there is from bilge to bottom of engine - hence one of the reasons for top mount starters. Have no idea what app your 6.2 was in nor how your older Volvo was set up. Volvo had top mount starters mounted in some apps as well.
merkfalc 01-11-2016 12:23 PM
Looks like I'm good to go as far as starter locations are concerned.
