-   -   Does anybody run twin EFi engines with multiple fuel tanks? (https://www.offshoreonly.com/forums/general-q/334313-does-anybody-run-twin-efi-engines-multiple-fuel-tanks.html)
phughes69 03-26-2021 10:04 AM
Originally Posted by snapmorgan (Post 4783118)
It takes 2 imco 6 port fuel valves. In 1 position, each engine pulls from and returns fuel to its own saddle tank. In the other position both engines pull from and return fuel to the main tank. Pretty simple really. I can draw you a diagram if you promise not to laugh at it
That would work but $1500 is not in the budget for just fuel selector valves.
snapmorgan 03-26-2021 10:21 AM
Even if you return the fuel to the filter heads instead of the tank, you will still need 2 3 port valves to switch between the saddle tanks and the main tank. I doubt that there is that much difference between the cost of the 3 port and the 6 port valves. The only other option that I can see is to T all of the tanks together with valves on the saddle tanks so that you can gravity feed them into the main tank, or put a fuel pump on the saddle tanks and pump them into the main tank. I am personally not very keen on either of those options. I would end up forgetting to close the valves or shut off the pumps and overfill the main tank. I would do it correctly the first time and be done with it. One switch on the dash will work both valves and they will also switch the fuel gauge if you only have 1.
Rookie 03-26-2021 01:01 PM
I thought coast guard regulations didn't allow you to return gasoline back to the tank. That is why Mercury returns back to the filter head. I could be totally wrong too.
SB 03-26-2021 01:28 PM
MOst of the ski/wake boats not just return back to the tank but have the pump in the tank like vehicles.
snapmorgan 03-26-2021 01:49 PM
There is no mention of a return line in the USCG fuel system standards, it just states what material the lines should be made of. This is old info from a boat builders handbook from when I worked at Celebrity boats though.
Rookie 03-26-2021 02:14 PM
Thanks guys
