Fuel Injection????
Greetings,
I'm going to be building a 350 engine for my boat over the winter and was considering buying the components and going with fuel injection over carburation. My questions are: Is it worth the expense? What system? Mercruiser's systems or from an aftermarket component maker like the accel or edelbrock multiport systems? Should I look at buying used such as this EBAY Thanks |
I don't remember the maker of the FI system for Merc but all I can say is DO NOT BUY IT.
That is old technology and it does not even come with the computer. Keep looking for a newer EFI or go with a Holley 4 injector TBI system. |
While fuel injection works real well, I feel that if I were building a motor from scratch as you are, I would prefer the ease of tuning associated with a carb. I am not saying that you can't get an injection system to work properly, but it takes alot more than getting a carb jetted correctly.
If you wanted to stay with stock power, then a Mecruiser system would be the way to go. Personally, I don't think that you can beat the reliablity of a factory Mercuiser injection system. Once yuo start modifying the motor for more power, the Merc. injection ECU needs to be re-calibrated which can lead to problems. P.S. If you are looking for a real good set of small block heads, drop me a private message, I have a set that I don't need anymore. |
Hmmm.... tough decision. I guess if it were me, I'd go with a carb because of the reasons listed above. On the other hand, if you were going to buy a complete engine package and have it dropped in, the EFI would be my choice (as a matter of fact, it WAS my choice last year). CM454mag pegged it.
| All times are GMT -5. The time now is 11:08 PM. |
