VST or Aeromotive?
#51
Cut off the front of the fuel rail where the stock regulator was, drilled and retapped to accept a npt to an fitting. Same with the rear of it. Good clean look now. Mounted the merc separator on the front bulkhead, fuel pump mounted low in the bilge, fuel enters the rail from the rear through a 10 micron filter, exits at the front of the rail to the vacuum regulated bypass regulator on the bulkhead. Excess fuel bleeds off to the merc separator for now.
#52
Before[ATTACH=CONFIG]557767[/ATTACH][ATTACH=CONFIG]557768[/ATTACH]after[ATTACH=CONFIG]557773[/ATTACH]Also added some color to the plenum while I had it off
#53
Or $70 here with the pickup filter that Merc charges $300+ for!
http://www.speedncustommarine.com/Fu...3plqscsfapp001
