-   -   Cig on board charger (https://www.offshoreonly.com/forums/general-q/334525-cig-board-charger.html)
F-2 Speedy 02-12-2016 09:23 AM
I have a factory battery charger in my TG, works fine, will it go into monitor / maintain mode if left plugged in ?
ROB FREEMAN 02-12-2016 10:42 AM
good now I'll use mine. Lol. Sounds like they charge then go to maintain after charged. I'll problem only turn mine on three times a winter for a day. Though,, oh chit I misread you're post. I hope it works that way. Let me know. U be gunny pig. 😊
F-2 Speedy 02-13-2016 07:18 AM
Well Rob, 75 views and nothing
sonic700 02-13-2016 07:25 AM
In the summer I have it plugged in with the charger on all week and never had an issue. It's not the original. Not sure if they have different set ups
smokin' gun 02-13-2016 07:27 AM
I leave mine plugged in all the time never an issue .fact install on 2003 cig
seafordguy 02-13-2016 07:46 AM
Leave mine on for longer periods a lot.
During the winter I usually plug it in a half a dozen times for a couple days each time
jbraun2828 02-13-2016 07:48 AM
Mine stays plugged in all winter. Has a red light on when it's charging and a green light when it's maintaining
cmattj 02-13-2016 07:51 AM
My 2007 uses a Factory installed Dual Pro. http://www.dualpro.com/project/professional-series/
You may want to look a what series or model charger you have to see it specs , most chargers over that last decade or so are designed to be left plugged in (so they say).
I checked it often the first day I left the boat plugged for the same fear of leaving charging batteries unattended.
As advertised to dropped to 3 millamps and voltage remained at 12.9 on my test meter with no battery temp at all.. Good to go.
Keep in mind that the health of the battery will determine if charging or just maintaining the battery is needed. A battery with issues can keep the maint free charger cycling and working continuously.
I still check them every few days or at least weekly . As Jbraun stated green lights are comforting!
F-2 Speedy 02-13-2016 08:55 AM
Thanks guys, the boats four hours from me, I'll check the model # next time I'm there, I currently have two separate chargers on the batteries that do have maint. mode
