I'd take more (reliable) horsepower or higher Bravo drives any day, even if they both got me to the same top speed. My frame of reference is what I would call performance pleasure boating, not racing. If I had a step bottom boat, I may have a different opinion as I think those tend to respond better to high X-dimensions.
There is a reason they are always for sale on these sites. The same ones are probably being passed around like a Fountain skank. |
Originally Posted by BenPerfected
(Post 4404475)
You are on the right track. The IMCO skag is shorter than the Merc so the Sportmaster scrubs 1-2 MPH compared to the IMCO but both will allow you to raise your X. If you drives are currently 5-7" below the bottom, you likely have a + 7-10 MPH opportunity if you are up for a total re-rig of the drive train. The re-rig cost will likely exceed the value of the boat. However, if you do this enough times, I have seen some fools exceed the value of their boat by 10X.:D
Thanks for all the input guys! I'm buying the shorty Sportmasters, soon I will see what raising the X does on a straight bottom Formula. Benperfected, it sounds like you have been through many stages in your project. When you first added the short drives, what was the effect on the props? I'm currently running Bravos, and I'm at least 400 rpms from where I really want to be at WOT rpm's. Did both rpms and slip increase with the addition of the shorty drives? When I work on the boat this weekend, I'm going to get some measurements and I'll report back.
Find a set of Imco's not Sportmasters
What what I've read, the only reason the IMCO is faster is because the skeg is longer on the Sportmaster. That is a pretty easy fix, I'll just trim the skeg to the same length as the IMCO. One of the members on here tested the Sportmaster and Imco's back to back and there was no speed advantage at all to either until over 100 mph. At which point the advantage went to the Sportmaster I believe.
3 Attachment(s)
I have used both Imco & Sportmaster shorties with great results. The Imco has a longer case, and a bit more nose cone. I will add that the Imco IMO does need modification to the water inlet for a couple of reasons. First, water pressure, second cavitation.[ATTACH=CONFIG]551131[/ATTACH][ATTACH=CONFIG]551132[/ATTACH][ATTACH=CONFIG]551133[/ATTACH]
The pics are of the Imco, you can see the water pickup is long and sloppy, it also causes cavitation as you can see from the pic. It actually burned into the case, and what do you think that does to the props performance... not good. But The nice thing is it can be modified to fit your exact needs for water pressure as you can see what I do in the pic. Both drives have long skags that too can be cut down to fit your needs. Both Merc & Imco make the skags long to accommodate a very high X for cats. They cast the cases not knowing what application they will be used on. I cut different lengths off of both brands to fit there application. Usually 2 to 4 inches. I don't think you can go wrong with either case, I will say, I think there is more used Imco's out there for sale, and if you decide to sell for whatever reason, the Merc's will bring more resale. Will you see big speed increase? You don't know till you try. I will also add that every boat that I put shorties on, drove and handled better, that is if it worked out. |
One more thing if you have to adjust the Merc water pressure, you simply drill, tap and plug water inlets until you get you desired water pressure. So the Merc might be a better buy for you if you can find them reasonable. Also as stated by someone above, if you get used drives, have them inspected for wear.
Congrats to you for taking the plunge, I am following this with great interest as a fellow straight bottom Formula owner. I run the same speeds as you, only difference is my hull has a notch at the transom. No one has really tested shorties thoroughly (several different props, etc) and documented it well.
I do need a lot of trim to hit top speed, usually about 6 on the indicators |
What kind of engines are you running rex? The 336 is very similar to the 311, which even though bigger, typically runs the same speed with the same power as the 292. I've got to run a lot of trim on my boat as well. The best prop I ran on mine was a Hydromotive QIV. The only reason I kept the bravos is Blades said he could make them out preform the hydros. I was going to ship them off to him to work on, but now with the shorties I don't want to do anything with the props until I know how this new set up is going to run.
Originally Posted by rexcramer1
(Post 4405460)
| All times are GMT -5. The time now is 03:47 PM. |
