HaxbySpeed
can you call me or give me a number so I can call you.
I put together a list of pieces to install EFI on my 598 and I would like your opinion please. Steve 616 723-1720 |
steve,did he contact you?
Yes he did.
I have a list of parts I need him to look at. AEI-12301 10 micron post filter AEI-12304 100 micron pre filter EDL-3658 fuel rail EDL-7136 intake manifold FST-54091 throttle body HLY-12-890 fuel pump HLY-512-504-5 fuel reg. HLY-522-668 fuel inj. HLY-534-10 coolant temp sensor HLY-534-20 air temp sensor HLY-538-13 MAP sensor or should I get the 3 BAR? HLY-554-100 O2 sensor HLY-554-102 pressure sensors ( 2 ) HLY-554-113 ECU HLY-556-101 DIS kit HLY-556-111 other parts of DIS kit HLY-558-104 main wire harness HLY-558-200 injector harness HLY-558-308 power harness MOR-65090 10.2 spacers for intake MSD-8513 distributor hole plug / oil pump drive What do you think??? Anything I am missing??? |
Yes AED 850 HO modified carb.
just messing with you. Throttle cable hardware ? |
What would you suggest. Never built an EFI motor. Unless you want to count the HOLLEY first generation EFI throttle body system that I installed on the Glastron.
Fuel lines and a provision for a return line to the tank. More of a fabrication/installation issue than parts but none the less...
Yeah I figured there would be a LOT of hardware and plumbing. My tanks have provision for return lines. I will put together a list of parts once I start the install. I am just trying to get the big ( and expensive parts) in one order.
For a return line, you can use a billet aluminum radiator hose insert used for an added temp sensor for aftermarket gauges. Just drill and tap the original npt hole for whatever size you need. Let me know if you need an example.
Both of my tanks have a tap that I can use for a return line.
Well that makes it easy :D
| All times are GMT -5. The time now is 03:03 PM. |
